Help Please with 3cx No Voice
Discussion in '3CX Phone System - General' started by kevinmana, Aug 23, 2015.
  1. kevinmana
    Aug 23, 2015
    Hi All,
    I am new with 3cx pbx system. Here is my LAN: Internet -> mikrotik -> LAN
    mikrotik : 192.168.100.1
    3cx server IP : 192.168.100.184
    Port: 5000,5060,5090,10000-20000
    Phone Extention: 100 at Home, 200 at Laptop used from outside my LAN/Home
    Here is my mikrotik filter and nat
    /ip firewall filter
    add action=accept chain=forward disabled=no dst-address-list=protected_host \
    dst-port=5060,5090,10000-20000 protocol=udp
    dst-port=5060,5090,5000 protocol=tcp
    /ip firewall nat
    add action=dst-nat chain=dstnat disabled=no dst-port=10000-20000 in-interface=\
    Internet protocol=udp to-addresses=192.168.100.184
    add action=dst-nat chain=dstnat disabled=no dst-port=5060,5090 in-interface=\
    add action=dst-nat chain=dstnat disabled=no dst-port=5060,5090,5000 \
    in-interface=Internet protocol=tcp to-addresses=192.168.100.184
    add action=masquerade chain=srcnat disabled=no src-address=192.168.100.0/24
    SIP 5060/5061 disable
    From 3cx pbx server I did firewall checker and all passed. ext 100 and 200 success registered.
    When i try to call from outsite my home using ext 200 to ext 100 or ext 999, i can not hear any voice.
    Please some one help me what i miss in here.
    Thank you
  2. complex1
    complex1 Active Member
    Jan 25, 2010
    813
    46
    I am not familiar with mikrotik but what I am missing is Port Forwarding of the RTP (audio) ports 9000-9199 UDP.
    SIP 5060/5061 are disabled and the firewall checker passes all tests?????
    Please read:
    http://www.3cx.com/blog/docs/ports-used/
    http://www.3cx.com/docs/firewall-router-configuration-voip/
  3. leejor
    11,073
    323
    The fact that you are not hearing audio at the remote end would suggest that the problem may be at that end. Normally, for a single device, no port forwarding is required at the remote end. I find that the more "complicated" the router in use, the more chance of problems If there is a firewall that is blocking some ports, then that may be the issue.
    Here is a list of all of the required ports at the 3CX PBX end...
    And some additional reading...
  4. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,530
    298
    Mikrotik works quite well - as long as the proper ports are open as mentioned by others. Right off the bat I see the 9k range was not opened.
