Help - Service keeps crashing
Discussion in '3CX Phone System - General' started by Anonymous, Oct 27, 2006.
  1. Anonymous
    Anonymous Guest
    I have installed the current Beta version on 2 computers. It is working good on 1 computer. I am trying to figure out why 3CXPhoneSystem.exe keeps crashing on one of the computers.
    I am running Windows XP SP2 with all the Windows Upates up to date, 2.4 Ghz/768 MB RAM.
    Thanks,
    Mike
  2. 3CXsupport
    3CXsupport New Member
    Aug 21, 2006
    193
    I am sorry to hear about your problems, but we have had no issues with regards of repeated crashed.
    Can you describe any differences on the second machine? Does it have a history of any similar problems (even remotely similar) ? Is there any 'particular' software installed on the second machine that may be somehow conflicting?
