Help setting up inbound direct SIP calls
Discussion in '3CX Phone System - General' started by BigB, Oct 4, 2011.
  1. BigB
    May 27, 2011
    6
    I am attempting to set up inbound direct sip calls. I have read the WIKI and whatever I can find on this subject but I cannot get calls through to my PBX. My domain name is register with namecheap and so I am attempting to complete direct sip by adjusting my domain records. My router has a static IP address. I will call it 12.34.56.78. Port 5060 is set up to forward calls to my 3CX PBX IP address. My setup works fine with my usual voip provider.
    In 3CX advanced setting I have added "sip.mydomain.co.uk" for my local sip domain.
    So far I have added the following to the domain setting in my namecheap control panel:
    HOST Name
    Host name - IP - Record Type - TTL
    @ - 11.22.33.44 - A(Address) - 1800
    @ - http://www.mydomain.co.uk - ULR Redirect - 1800
    www - ghs.google.com - CNAME(Alias) - 1800
    Sub Domain Settings
    sip - 12.34.56.78 - A(Address) - 1800
    SRV setting
    service - protocol - prioroty - weight - port - target
    _sip _udp 20 - 1 - 5060 sip.mydomain.co.uk
    _sip _tcp 20 - 1 - 5060 sip.mydomain.co.uk
    When I attmpt to call my digital receptionist (8002) on 8002@sip.mydomain.co.uk the call is not getting through to my 3CX server.
    Can anyone see where I am going wrong? Thanks in advance for any help.
    NB. Is it OK for a sub domain to have a different IP address?
  2. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    You still need to create DIDs to make direct SIP working. If necessary create dummy voip provider with DID numbers like 8000, 8001, 8002 pointing to extensions 8000, 8001, 8002, ...
    This is quite similar to IPkall service (in USA) which uses direct SIP calling.
    Hope this helps.
    Regards
  3. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Direct SIP is the external (anonymous) access to the system and routing is very limited for this type of the calls.
    By using Direct SIP you can call only an extension which has explicitly defined "SIP ID".
    For example, if SIP ID of an extension is set to "john" then Direct SIP calls to the user john@sip.mydomain.co.uk will be routed to this extension. Calls to unknown "SIP IDs" are rejected as "Unidentified incoming call". The internal number is NOT a "SIP ID".
    If you need to route Direct SIP calls to the objects which are not an extension (DR, Queue, Ring Group etc.) then you need to explicitly define receiver as the extension with SIP ID and then use forwarding rules to route calls to the required destination.
    Regards
  4. BigB
    May 27, 2011
    6
    That did it. Works fine so, much to my surprise, my domain setting were OK. :D
    Thanks for your help
  5. SY
    3CX Support
    Jan 26, 2007
    1,825
    thanks for update
    Personally, I'm glad to know that all parts have been adjusted to each other and "Direct SIP" works
    Cheers!
