Help setting up incoming with Vitelity
Discussion in '3CX Phone System - General' started by joshabts, Aug 20, 2007.
  1. joshabts
    Aug 20, 2007
    16
    Hello all,
    I am new to 3CX and am looking at using it for my small business. However I am having trouble setting up this server with Vitelity service. I have read of many people using 3CX with Vitelity but I cannot seem to be able to configure it to receive incoming calls.
    I have setup the VoIP provider and DID number in 3CX and it reports that the line successfully registers. However when I try calling the number it rings busy and I get a failed call notification from Vitelity saying CHANUNAVAIL. When I contact them they are telling me this is because I am not registered with their servers. However 3CX still reports that I am. I have NAT enabled in Vitelity panel and have forwarded ports 5060, 5061, and 10000-20000 to my 3CX server. I have also setup a DNS name with my IP since I have a dynamic address.
    What other settings did people with Vitelity have to do or can someone give me a quick step by step for setting up service with Vitelity?
    Any help would be greatly appreciated and I can provide any other settings people need to know to help me.
    Thank you!
    Joshua Abts
    PS I also forgot to mention that I can make outgoing calls via Vitelity just fine.
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Please enable the log level to "Verbose (only used for debugging purposes)". Restart all 3cx services or restart 3cx box. Then post the log here again. It maybe speed up to fix your issue.
    Have you config the DID rules?
  3. joshabts
    Aug 20, 2007
    16
    17:33:10.000|.\CallMgr.cpp(75)|Log2|CallManager|CallMgr::Initialize:[CM100000] Start 3CX PhoneSystem Call Manager
    17:33:10.000|.\CallMgr.cpp(76)|Log2|CallManager|CallMgr::Initialize:[CM100001] Version: 3.1.2434.0
    17:33:10.296|.\CallMgr.cpp(114)|Log2|CallManager|CallMgr::Initialize:[CM100002] Default Local IP address: 172.168.0.2:5060
    17:33:10.296|.\CallMgr.cpp(122)|Log2|CallManager|CallMgr::Initialize:[CM100003] ** Initializing SIP stack **
    17:33:10.312|.\CM_Stack.cpp(28)|Log2|SipStack|CallMgr::Stack::Initialize:[CM106000] ** Adding transports **
    17:33:10.343|.\DBAccessor.cpp(85)|Log2||DBA:[CM109000] ** Database connection Ok **
    17:33:10.359|.\SLServer.cpp(30)|Log2||ListenConnect:[CM114000] SL: connected voippbx:0/MediaServer at [voippbx]/MediaServer
    17:33:10.359|.\MSInterface.cpp(686)|Log2||MediaServerConnected:[CM112000] Media Server is connected
    17:33:10.515|.\CallMgr.cpp(244)|Log2|DUM|CallMgr::DumThread::thread:[CM100004] ** Enter DUM Thread **
    17:33:10.515|.\Registrar.cpp(42)|Log2|Registrar|ServRegs::checkExpiration:[CM113000] Registration for sip:100@172.168.0.2 has expired
    17:33:10.968|.\SLServer.cpp(30)|Log2||ListenConnect:[CM114000] SL: connected voippbx:0/VoiceBoxManagerService at [voippbx]/VoiceBoxManagerService
    17:33:11.125|.\CM_Stack.cpp(88)|Log2|SipStack|CallMgr::Stack::thread:[CM106001] ** Enter Stack Loop **
    17:33:11.234|.\StunClient.cpp(67)|Log2|STUN|StunClient::process:[CM115001] Send initial STUN request to 80.239.235.209
    17:33:11.359|.\StunClient.cpp(84)|Log2|STUN|StunClient::process:[CM115002] STUN resolved external IP=24.222.111.151:5060 by server 80.239.235.209
    17:33:12.078|.\StunClient.cpp(84)|Log2|STUN|StunClient::process:[CM115002] STUN resolved external IP=24.222.111.151:5060 by server 64.69.76.23
    17:33:12.109|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='20000' device='Vitelity 877#'
    17:33:12.109|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "8777654321"<sip:myuser@inbound4.vitelity.net>
    17:33:12.140|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='20000' device='Vitelity 877#'
    17:33:12.140|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "8777654321"<sip:myuser@inbound4.vitelity.net>
    17:33:12.281|.\Registrar.cpp(141)|Log2|Registrar|ServRegs::eek:nAdd:[CM113002] Registered: Ext.100
    17:33:12.468|.\Registrar.cpp(381)|Log2|Registrar|ClientRegs::eek:nSuccess:[CM113005] Registration of sip:myuser@inbound4.vitelity.net is successful
    17:33:12.578|.\Registrar.cpp(381)|Log2|Registrar|ClientRegs::eek:nSuccess:[CM113005] Registration of sip:myuser@inbound4.vitelity.net is successful
    17:33:14.906|.\SLServer.cpp(30)|Log2||ListenConnect:[CM114000] SL: connected voippbx:5483/IVRServer at [voippbx]/IVRServer
    17:33:14.906|.\IVRInterface.cpp(249)|Log2||IVRConnected:[CM111000] IVR Server is connected
    17:35:05.781|.\SLServer.cpp(30)|Log2||ListenConnect:[CM114000] SL: connected voippbx:0/PHPExtension_0 at [voippbx]/PHPExtension_0
    17:40:25.796|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='20000' device='Vitelity 877#'
    17:40:25.796|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "8777654321"<sip:myuser@inbound4.vitelity.net>
    17:40:26.218|.\Registrar.cpp(381)|Log2|Registrar|ClientRegs::eek:nSuccess:[CM113005] Registration of sip:myuser@inbound4.vitelity.net is successful
    18:19:16.328|.\Registrar.cpp(195)|Log2|Registrar|ServRegs::eek:nRemove:[CM113003] Unregistered: Ext.200
    18:19:52.046|.\Registrar.cpp(141)|Log2|Registrar|ServRegs::eek:nAdd:[CM113002] Registered: Ext.200
    18:30:18.031|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='20000' device='Vitelity 877#'
    18:30:18.031|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "8777654321"<sip:myuser@inbound4.vitelity.net>
    18:30:18.578|.\Registrar.cpp(381)|Log2|Registrar|ClientRegs::eek:nSuccess:[CM113005] Registration of sip:myuser@inbound4.vitelity.net is successful
    19:22:33.281|.\Registrar.cpp(195)|Log2|Registrar|ServRegs::eek:nRemove:[CM113003] Unregistered: Ext.200
    21:54:35.609|.\Registrar.cpp(141)|Log2|Registrar|ServRegs::eek:nAdd:[CM113002] Registered: Ext.200
    That is my log output from recent times. Numbers have been changed for privacy concerns.
    I have created the VoIP provider but even when I created a new DID number that used the provider I had created, it still gave the same result.
    Thanks!
  4. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Hi joshabts,
    Referred to your log, there is not found any incoming call. Please issue a call to your 3CX box. Then capture the log which shows your problem.
    The following log shows "NO DID rule for 558"
    The following log shows "DID rule for 135, and ring EXT 135"
    Regards,
    5QG4
  5. joshabts
    Aug 20, 2007
    16
    This was a log with multiple calls made to the DID number throughout it. From what I can see and what I understand you to be saying, is that the calls aren't even reaching my PBX. Hence nothing in the log.
    That said, I spoke with Vitelity and they keep telling me I am not properly registered because they do a sip debug peer 'myuser' and they are getting no IP found for peer. Which tells them my PBX is not registered as it should be.
    I am not sure where to check on what exactly is sent through the registration or what ports possibly need to be open for the registration to successfully complete all the way. Is there a control port I am missing or need to check on? Is there any log file that I can check on for why registration may not complete properly even though 3CX says it does and shows the line as registered?
    Any one else having/had this problem?
  6. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    For port forwarding please read http://www.3cx.com/forums/viewtopic.php?t=1697&highlight=port+sticky
    Some good info there:
    Didn't see some of these (eg. 9000 - 9003) in your list posted. And even though this might seem self-evident, make sure forwarding is both ways (WAN <=> LAN IP) as needed.
    Hope this helps.
    Mirza.
  7. joshabts
    Aug 20, 2007
    16
    All of those ports have been opened and forwarded to my server. However I still have the same result when trying to receive calls.
    I can though, make an outgoing call and it goes out through Vitelity just fine. This really sounds like a problem with their end does it not?
  8. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    Just a suggestion since I have no knowledge or experience with that specific provider - check your current external IP and use that in their setup, just to test. Even a dynamic IP stays stable for a few hours. I have always tried to eliminate as many variables as possible when troubleshooting, and the domain forwarding for your dynamic IP is definitely an unknown.
    I have also found it more stable in 3CX setting up my DID numbers as VoIP providers inbound only, works great for me whenever possible.
  9. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Hi joshabts,
    Referred to your log, your WAN IP had been resolved by STUN. It highlighted in red color as below.
    Regards.
  10. tjabaut
    tjabaut New Member
    Jul 24, 2007
    123
    joshabts,
    What are your registration settings for VoIP for Vitelity.
    I mean could ytou please document out each and every option that you have enabled.
    I have Vitelity and it has worked flawlessly for months now. I would be happy to help.
    I know RobLloyd is also a fellow Vitelity user, and together we should be able to assit.
  11. joshabts
    Aug 20, 2007
    16
    Okay in this post I will try my best to cover all of the settings I currently have.
    In Line management, I currently have one VoIP provider.
    Provider Name: Vitelity 877#
    External #: 8777654321
    Authentication ID: myuser
    Password: myvitelitysecret
    Route Inbound calls during office hours to extension: 200
    Route Inbound calls during non-office hours to extension: 200
    Internal number: 20000
    Outbound caller ID: 8777654321
    Allow outbound calls: checked
    Answer incoming calls: checked
    Answer after: 0 seconds
    Max simultaneous calls: 10
    If I edit Providers/Gateways and edit my Vitelity 877# provider, these are those settings...
    Registrar proxy hostname: inbound4.vitelity.net
    Registrar proxy port: 5060
    Outbound proxy hostname: outbound1.vitelity.net
    Outbound proxy port: 5060
    STUN Server hostname: stun.xten.com
    STUN server port: 3478
    Registration settings->
    Time between registrations: 3600s
    Require (optionally: authorized) registration for: Both in-out calls
    Which IP to use in 'Contact' field for registration: External (STUN resolved)
    Codec Priorities->
    Available: Speex
    Assigned codecs: G.711 U-law, G.711 A-law, GSM-FR
    Provider capabilities->
    Supports re-invite: unchecked
    Supports replaces header: disabled
    Location of destination number->
    To.user field: checked
    Request-Line-URI field: checked
    'RemotePartyID;party=called' field: unchecked
    Other options->
    PBX Delivers audio: checked
    Use IP in 'Contact' to recognize source: unchecked
    IP Range: disabled
    Caller-ID is in 'user' part of (one of following): From Field
    Called-Number (for inbound calls) is in: To Field
    Then under General Settings I have the following
    SIP Port: 5060
    Internal calls First Port: 7000
    Internal calls Last Port: 7499
    External calls first port: 9000
    External calls last port: 9003
    STUN Server options
    Default STUN server address: stun.3cx.com
    Default 2 STUN server: stun2.3cx.com
    Timeout for STUN: 3000ms
    Recheck every: 1200s
    Settings for direct SIP calls
    Allow calls to external URI: not checked
    Local SIP domain: <blank>
    Logging level: verbose
    I think that pretty much covers all of the settings, if you need another page, let me know thanks!
    Josh
