Help setting up
Discussion in '3CX Phone System - General' started by rich1231, Mar 6, 2010.
  1. rich1231
    Jan 2, 2010
    I have 3cx running on my laptop just to test.
    I have a network that i have some Linksys SPa942's attached. I can get them registered on the PBX no problem.
    However the moment i hit any number and press dial i get the call ended tone.
    I cannot even dial other extensions.
    Router/Firewall is forwarding ports fine to laptop.
    SIP provider is Gradwell.
    I dont know if there are multiple issues (likely) or just the one of the phone extensions not being configured correctly. Anyone have any suggestions as to what I can try?
    10,781
    287
    First , have a look at the 3CX logs to see if the call is even getting into 3Cx and if it. or the phone itself is rejecting the dialed digits.
    Did you do any changes to the dialplan in the SPA942?
  3. rich1231
    Jan 2, 2010
    Hi there,
    thank you for the reply.
    I changed the dialplan as per the setup instructions on this site to [X*].
  4. leejor
    10,781
    287
    It's always best to build a dialplan to suit the particular numbers you will be dialling in your set-up. It helps the calls go through faster when you finish dialling and allow you to block certain numbers if you wish. There are a number of sites with info on the Sipura/Linksys/Cisco dialplans. Here is a link to one of them that can get you started...http://www.netphonedirectory.com/pap2_dialplan2.htm
    Don't forget that some dialplans are created for use in a Gateway to send digits out to different trunks based on number dialled. When used in a set, as you are, a dialplan is used to pre-screen, or manipulate numbers before being sent out to 3CX (or another, single, VoIP provider), which will then route then call based on the digits.
