Help Trunk Between 3CX and Cisco UCM
Discussion in '3CX Phone System - General' started by mikegillespie, Jan 13, 2017.
  1. mikegillespie
    Feb 15, 2012
    19
    HI,
    The goal is to trunk the 3CX (v14) and UCM together for extension dialing and UCM access to PSTN trunks attached to 3CX.
    1. The Cisco devices associated with the UCM must allowed to dial to extensions and trunks on the 3CX (v14)
    2. The SIP devices registered to the 3CX must be allowed to dial extensions of Cisco Devices registered to the UCM
    We have established a generic trunk (no authentication) between the 3CX and UCM.
    3CX SIP endpoints can call devices registered to the UCM.
    Devices registered to the UCM cannot dial extensions on 3CX or use PSTN trunks.
    If I created a DID for a 3CX extension on the 3CX Trunk inbound from the UCM, the caller from the UCM device can reach the phone on the 3CX. The problem with this is that it doesn't make sense to create a DID for each extension on the 3CX and they will not be able to dial out to the PSTN this way.
    Any help with this is much appreciated.
    Mike
  2. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    Using trunks of 3CX is not possible from other PBX extensions when you interconnect PBXs via generic SIP trunk, mostly for security reasons.
    You have to use a bridge on 3CX to accomplish this, but may experience problems with caller's IDs.
    If you are using generic SIP trunk, you need DDI table (inbound rules) in order to call extensions in 3CX.
    datamerge likes this.
  3. leejor
    10,758
    286
  4. mikegillespie
    Feb 15, 2012
    19
    I have tried the bridge, however, i am told the CUCM is not capable of registering to a SIP server on it's own. Is there any other way?
  5. leejor
    10,758
    286
    How does it normally interface to a provider? Are there various methods (types of Interface cards) available?
    From you original post, it would seem that you have established a VoIP connection between the two. Do you have 3CX registering to the CUCM as if it were a Provider? If that is the case, then I'd be surprise if the CUCM can't register to a VoIP provider. The Bridge trunk settings will allow 3CX to appear as that.
    #5 leejor, Feb 2, 2017
  6. mikegillespie
    Feb 15, 2012
    19
    Hi, I had set up a generic provider with no authenticaton and they registered. The issue is, endpoint registered to the CUCM would not me able to dial any extensions on the 3cx with there being a DID and endpoint restrered to the CUCM would not be able to use the trunk on the 3CX to make external calls.
    Did i miss something? its quite possible.
    Mike
  7. leejor
    10,758
    286
    So you had 3CX registered to the CUCM? In that case, any calls in the direction of 3CX would be routed as a whole trunk group, all incoming calls to one destination, or as DIDs (If the CUCM was capable of that). If you set-up a Bridge trunk, you can send digits, routing calls to specific extensions, or outbound rules. Bridge trunks can be set-up as a master or slave. So... 3Cx can register to a provider, or in this case , the CUCM, or it can act as a provider allowing registration from the CUCM. If you are attempting to allow extensions on the CUCM to access outbound trunks on the 3CX PBX, then a bridge trunk would be the best way of achieving that.
  8. mikegillespie
    Feb 15, 2012
    19
    I have them setup as a bridge and here is what I see when a call is attempted from an endpoint on the CUCM into the 3CX.
    Code:
    07-Feb-2017 09:35:05.388   Leg L:776.1[DirSip:DirectSIP<<"SX10 x5506"<sip:5506@jwlindsay.ca>;tag=505723~5dea1feb-fd7f-4c03-9dee-7de56557612c-21453595] is terminated: Cause: BYE from PBX
    07-Feb-2017 09:35:05.338   Leg L:776.2[Extn:200] is terminated: Cause: 488 Not Acceptable Here/INVITE from 10.0.7.127:5063
    07-Feb-2017 09:35:05.338   L:776.1[DirSip:DirectSIP<<"SX10 x5506"<sip:5506@jwlindsay.ca>;tag=505723~5dea1feb-fd7f-4c03-9dee-7de56557612c-21453595] failed to reach Extn:200, reason Not Acceptable HereReason Unknown
    07-Feb-2017 09:35:05.338   Call to T:Extn:200@[Dev:sip:200@10.0.7.127:5063] from L:776.1[DirSip:DirectSIP<<"SX10 x5506"<sip:5506@jwlindsay.ca>;tag=505723~5dea1feb-fd7f-4c03-9dee-7de56557612c-21453595] failed, cause: Cause: 488 Not Acceptable Here/INVITE from 10.0.7.127:5063
    07-Feb-2017 09:35:05.338   [CM503003]: Call(C:776): Call to <sip:200@10.10.150.20:5060> has failed; Cause: 488 Not Acceptable Here/INVITE from 10.0.7.127:5063
    07-Feb-2017 09:35:05.277   [CM503025]: Call(C:776): Calling T:Extn:200@[Dev:sip:200@10.0.7.127:5063] for L:776.1[DirSip:DirectSIP<<"SX10 x5506"<sip:5506@jwlindsay.ca>;tag=505723~5dea1feb-fd7f-4c03-9dee-7de56557612c-21453595]
    07-Feb-2017 09:35:05.270   [CM503027]: Call(C:776): From: DirSip:DirectSIP<<"SX10 x5506"<sip:5506@jwlindsay.ca>;tag=505723~5dea1feb-fd7f-4c03-9dee-7de56557612c-21453595 ("SX10 x5506" <sip:5506@jwlindsay.ca:5060>)  to  T:Extn:200@[Dev:sip:200@10.0.7.127:5063]
    07-Feb-2017 09:35:05.270   [CM503004]: Call(C:776): Route 1: from L:776.1[DirSip:DirectSIP<<"SX10 x5506"<sip:5506@jwlindsay.ca>;tag=505723~5dea1feb-fd7f-4c03-9dee-7de56557612c-21453595] to T:Extn:200@[Dev:sip:200@10.0.7.127:5063]
    07-Feb-2017 09:35:05.270   [CM503001]: Call(C:776): Incoming call from DirSip:DirectSIP<<"SX10 x5506"<sip:5506@jwlindsay.ca>;tag=505723~5dea1feb-fd7f-4c03-9dee-7de56557612c-21453595 to <sip:200@10.10.150.20:5060>
    07-Feb-2017 09:35:05.270   NAT/ALG check:L:776.1[DirSip:DirectSIP<<"SX10 x5506"<sip:5506@jwlindsay.ca>;tag=505723~5dea1feb-fd7f-4c03-9dee-7de56557612c-21453595] REQUEST 'INVITE' - some of SIP/SDP headers may contain inconsistent information or modified by intermediate hop
       SIP contact header is not equal to the SIP packet source(IP:port):
          Contact address:10.0.4.62:5060
          Received from :10.0.4.62:34267
    07-Feb-2017 09:35:05.106   Leg L:775.1[DirSip:DirectSIP<<"SX10 x5506"<sip:5506@jwlindsay.ca>;tag=505721~5dea1feb-fd7f-4c03-9dee-7de56557612c-21453593] is terminated: Cause: BYE from PBX
    07-Feb-2017 09:35:05.096   Leg L:775.2[Extn:200] is terminated: Cause: 488 Not Acceptable Here/INVITE from 10.0.7.127:5063
    07-Feb-2017 09:35:05.096   L:775.1[DirSip:DirectSIP<<"SX10 x5506"<sip:5506@jwlindsay.ca>;tag=505721~5dea1feb-fd7f-4c03-9dee-7de56557612c-21453593] failed to reach Extn:200, reason Not Acceptable HereReason Unknown
    07-Feb-2017 09:35:05.096   Call to T:Extn:200@[Dev:sip:200@10.0.7.127:5063] from L:775.1[DirSip:DirectSIP<<"SX10 x5506"<sip:5506@jwlindsay.ca>;tag=505721~5dea1feb-fd7f-4c03-9dee-7de56557612c-21453593] failed, cause: Cause: 488 Not Acceptable Here/INVITE from 10.0.7.127:5063
    07-Feb-2017 09:35:05.096   [CM503003]: Call(C:775): Call to <sip:200@10.10.150.20:5060> has failed; Cause: 488 Not Acceptable Here/INVITE from 10.0.7.127:5063
    07-Feb-2017 09:35:05.000   [CM503025]: Call(C:775): Calling T:Extn:200@[Dev:sip:200@10.0.7.127:5063] for L:775.1[DirSip:DirectSIP<<"SX10 x5506"<sip:5506@jwlindsay.ca>;tag=505721~5dea1feb-fd7f-4c03-9dee-7de56557612c-21453593]
    07-Feb-2017 09:35:04.976   [CM503027]: Call(C:775): From: DirSip:DirectSIP<<"SX10 x5506"<sip:5506@jwlindsay.ca>;tag=505721~5dea1feb-fd7f-4c03-9dee-7de56557612c-21453593 ("SX10 x5506" <sip:5506@jwlindsay.ca:5060>)  to  T:Extn:200@[Dev:sip:200@10.0.7.127:5063]
    07-Feb-2017 09:35:04.976   [CM503004]: Call(C:775): Route 1: from L:775.1[DirSip:DirectSIP<<"SX10 x5506"<sip:5506@jwlindsay.ca>;tag=505721~5dea1feb-fd7f-4c03-9dee-7de56557612c-21453593] to T:Extn:200@[Dev:sip:200@10.0.7.127:5063]
    07-Feb-2017 09:35:04.976   [CM503001]: Call(C:775): Incoming call from DirSip:DirectSIP<<"SX10 x5506"<sip:5506@jwlindsay.ca>;tag=505721~5dea1feb-fd7f-4c03-9dee-7de56557612c-21453593 to <sip:200@10.10.150.20:5060>
    07-Feb-2017 09:35:04.976   NAT/ALG check:L:775.1[DirSip:DirectSIP<<"SX10 x5506"<sip:5506@jwlindsay.ca>;tag=505721~5dea1feb-fd7f-4c03-9dee-7de56557612c-21453593] REQUEST 'INVITE' - some of SIP/SDP headers may contain inconsistent information or modified by intermediate hop
    07-Feb-2017 09:35:04.790   Leg L:774.1[DirSip:DirectSIP<<"SX10 x5506"<sip:5506@jwlindsay.ca>;tag=505719~5dea1feb-fd7f-4c03-9dee-7de56557612c-21453591] is terminated: Cause: BYE from PBX
    07-Feb-2017 09:35:04.740   Leg L:774.2[Extn:200] is terminated: Cause: 488 Not Acceptable Here/INVITE from 10.0.7.127:5063
    07-Feb-2017 09:35:04.740   L:774.1[DirSip:DirectSIP<<"SX10 x5506"<sip:5506@jwlindsay.ca>;tag=505719~5dea1feb-fd7f-4c03-9dee-7de56557612c-21453591] failed to reach Extn:200, reason Not Acceptable HereReason Unknown
    07-Feb-2017 09:35:04.740   Call to T:Extn:200@[Dev:sip:200@10.0.7.127:5063] from L:774.1[DirSip:DirectSIP<<"SX10 x5506"<sip:5506@jwlindsay.ca>;tag=505719~5dea1feb-fd7f-4c03-9dee-7de56557612c-21453591] failed, cause: Cause: 488 Not Acceptable Here/INVITE from 10.0.7.127:5063
    07-Feb-2017 09:35:04.740   [CM503003]: Call(C:774): Call to <sip:200@10.10.150.20:5060> has failed; Cause: 488 Not Acceptable Here/INVITE from 10.0.7.127:5063
    07-Feb-2017 09:35:04.692   [CM503025]: Call(C:774): Calling T:Extn:200@[Dev:sip:200@10.0.7.127:5063] for L:774.1[DirSip:DirectSIP<<"SX10 x5506"<sip:5506@jwlindsay.ca>;tag=505719~5dea1feb-fd7f-4c03-9dee-7de56557612c-21453591]
    07-Feb-2017 09:35:04.647   [CM503027]: Call(C:774): From: DirSip:DirectSIP<<"SX10 x5506"<sip:5506@jwlindsay.ca>;tag=505719~5dea1feb-fd7f-4c03-9dee-7de56557612c-21453591 ("SX10 x5506" <sip:5506@jwlindsay.ca:5060>)  to  T:Extn:200@[Dev:sip:200@10.0.7.127:5063]
    07-Feb-2017 09:35:04.647   [CM503004]: Call(C:774): Route 1: from L:774.1[DirSip:DirectSIP<<"SX10 x5506"<sip:5506@jwlindsay.ca>;tag=505719~5dea1feb-fd7f-4c03-9dee-7de56557612c-21453591] to T:Extn:200@[Dev:sip:200@10.0.7.127:5063]
    07-Feb-2017 09:35:04.646   [CM503001]: Call(C:774): Incoming call from DirSip:DirectSIP<<"SX10 x5506"<sip:5506@jwlindsay.ca>;tag=505719~5dea1feb-fd7f-4c03-9dee-7de56557612c-21453591 to <sip:200@10.10.150.20:5060>
    07-Feb-2017 09:35:04.646   NAT/ALG check:L:774.1[DirSip:DirectSIP<<"SX10 x5506"<sip:5506@jwlindsay.ca>;tag=505719~5dea1feb-fd7f-4c03-9dee-7de56557612c-21453591] REQUEST 'INVITE' - some of SIP/SDP headers may contain inconsistent information or modified by intermediate hop
    07-Feb-2017 09:35:04.433   Leg L:773.1[DirSip:DirectSIP<<"SX10 x5506"<sip:5506@jwlindsay.ca>;tag=505717~5dea1feb-fd7f-4c03-9dee-7de56557612c-21453589] is terminated: Cause: BYE from PBX
    07-Feb-2017 09:35:04.382   Leg L:773.2[Extn:200] is terminated: Cause: 488 Not Acceptable Here/INVITE from 10.0.7.127:5063
    07-Feb-2017 09:35:04.382   L:773.1[DirSip:DirectSIP<<"SX10 x5506"<sip:5506@jwlindsay.ca>;tag=505717~5dea1feb-fd7f-4c03-9dee-7de56557612c-21453589] failed to reach Extn:200, reason Not Acceptable HereReason Unknown
    07-Feb-2017 09:35:04.382   Call to T:Extn:200@[Dev:sip:200@10.0.7.127:5063] from L:773.1[DirSip:DirectSIP<<"SX10 x5506"<sip:5506@jwlindsay.ca>;tag=505717~5dea1feb-fd7f-4c03-9dee-7de56557612c-21453589] failed, cause: Cause: 488 Not Acceptable Here/INVITE from 10.0.7.127:5063
    07-Feb-2017 09:35:04.382   [CM503003]: Call(C:773): Call to <sip:200@10.10.150.20:5060> has failed; Cause: 488 Not Acceptable Here/INVITE from 10.0.7.127:5063
    07-Feb-2017 09:35:04.295   [CM503025]: Call(C:773): Calling T:Extn:200@[Dev:sip:200@10.0.7.127:5063] for L:773.1[DirSip:DirectSIP<<"SX10 x5506"<sip:5506@jwlindsay.ca>;tag=505717~5dea1feb-fd7f-4c03-9dee-7de56557612c-21453589]
    07-Feb-2017 09:35:04.249   [CM503027]: Call(C:773): From: DirSip:DirectSIP<<"SX10 x5506"<sip:5506@jwlindsay.ca>;tag=505717~5dea1feb-fd7f-4c03-9dee-7de56557612c-21453589 ("SX10 x5506" <sip:5506@jwlindsay.ca:5060>)  to  T:Extn:200@[Dev:sip:200@10.0.7.127:5063]
    07-Feb-2017 09:35:04.249   [CM503004]: Call(C:773): Route 1: from L:773.1[DirSip:DirectSIP<<"SX10 x5506"<sip:5506@jwlindsay.ca>;tag=505717~5dea1feb-fd7f-4c03-9dee-7de56557612c-21453589] to T:Extn:200@[Dev:sip:200@10.0.7.127:5063]
    07-Feb-2017 09:35:04.249   [CM503001]: Call(C:773): Incoming call from DirSip:DirectSIP<<"SX10 x5506"<sip:5506@jwlindsay.ca>;tag=505717~5dea1feb-fd7f-4c03-9dee-7de56557612c-21453589 to <sip:200@10.10.150.20:5060>
    07-Feb-2017 09:35:04.248   NAT/ALG check:L:773.1[DirSip:DirectSIP<<"SX10 x5506"<sip:5506@jwlindsay.ca>;tag=505717~5dea1feb-fd7f-4c03-9dee-7de56557612c-21453589] REQUEST 'INVITE' - some of SIP/SDP headers may contain inconsistent information or modified by intermediate hop
  9. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    You probably need to adjust/normalize some SIP profile configuration settings?:confused:
    Code:
    #9 Sopock, Feb 7, 2017
  10. leejor
    10,758
    286
    Are there logs at the CUCM end that might explain what is "not acceptable" when calling Ext 200?
    This may not be the issue, but would seem to be of concern. Does your router do port substitution?
  11. mikegillespie
    Feb 15, 2012
    19
    Thanks Guys, I don't believe the router is doing any port substitutions. Also, I will be getting together with the Cisco UCM tech to see what their logs say soon.
    I changed the SIP domain in the 3CX to match what the UCM is set for and here are the new logs;
    Code:
    ; Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    07-Feb-2017 20:40:00.858   [Auth] Provided response (16f2bf37b5ecaf6565516e43dbb5a5bb doesn't match calc. (f7e1d9307effff98328414f8f3141632)
    07-Feb-2017 20:39:59.532   [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    Invite-UNK Recv Req INVITE from 10.0.4.62:44784 tid=1a96349d57ac4 Call-ID=1d585f00-89a168df-1a379-3e04000a@10.0.4.62:
    INVITE sip:200@10.10.150.20:5060 SIP/2.0
    Via: SIP/2.0/TCP 10.0.4.62:5060;branch=z9hG4bK1a96349d57ac4
    Max-Forwards: 69
    Contact: <sip:5506@10.0.4.62:5060;transport=tcp>;video;audio;+multiple-codecs-in-ans
    To: <sip:200@10.10.150.20>
    From: "SX10 x5506"<sip:5506@jwlindsay.ca>;tag=512426~5dea1feb-fd7f-4c03-9dee-7de56557612c-21453665
    Call-ID: 1d585f00-89a168df-1a379-3e04000a@10.0.4.62
    CSeq: 101 INVITE
    Expires: 180
    Session-Expires: 1800
    Min-SE: 1800
    Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
    Call-Info: <urn:x-cisco-remotecc:callinfo>;x-cisco-video-traffic-class=IMMERSIVE
    Date: Wed, 08 Feb 2017 00:39:59 GMT
    Supported: timer, resource-priority, replaces, X-cisco-srtp-fallback, X-cisco-original-called
    User-Agent: Cisco-CUCM11.5
    Allow-Events: presence
    P-Asserted-Identity: "SX10 x5506" <sip:5506@jwlindsay.ca>
    Content-Length: 0
    Remote-Party-ID: "SX10 x5506" <sip:5506@jwlindsay.ca>;party=calling;screen=yes;privacy=off
    Session-ID: 7b4a226d20e8fe93440723fcaa512425;remote=00000000000000000000000000000000
    Cisco-Guid: 0492330752-0000065536-0000000481-1040449546
    07-Feb-2017 20:39:31.112   [CM504001]: Endpoint Extn:202: new contact is registered. Contact(s): [sip:202@10.0.152.23:5063 / 202]
    07-Feb-2017 20:39:30.611   [CM102001]: Authentication failed for AuthFail Recv Req REGISTER from 10.0.0.65:5060 tid=56d5ce739d5d5ae8c176dbbb620d8463 Call-
    ID=B5BC76432F01D27A04802923BE84E16CD611318B90@10.0.0.65:
    REGISTER sip:10.10.150.20 SIP/2.0
    Via: SIP/2.0/UDP 10.0.0.65:5060;branch=z9hG4bK56d5ce739d5d5ae8c176dbbb620d8463
    Max-Forwards: 70
    Contact: <sip:104@10.0.0.65:5060>
    To: <sip:104@10.10.150.20>
    From: "Fax Server"<sip:104@10.10.150.20:5060>;tag=5f391d48
    Call-ID: B5BC76432F01D27A04802923BE84E16CD611318B90@10.0.0.65
    CSeq: 53698 REGISTER
    Expires: 1200
    Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, REFER
    Organization: Lindsay Construction
    Proxy-Authorization: Digest
    username="104",realm="3CXPhoneSystem",uri="sip:10.10.150.20",nonce="414d535c0eaaf9c200:5646da61b9cf8a4faca3b9dc9fe785b7",response="5679a32bc8a908740cb6237fe751d616",al
    gorithm=MD5
    Supported: timer
    User-Agent: www.te-systems.de XCAPI V3.3.185.0
    Content-Length: 0
    X-XCAPI-UUID: BC76432F01D27A04802A23BE84E16CD6
    07-Feb-2017 20:39:30.611   [Auth] Provided response (5679a32bc8a908740cb6237fe751d616 doesn't match calc. (9adac5fea3d90d6cff68837552c7463c)
    07-Feb-2017 20:39:30.383   [CM504001]: Endpoint Extn:201: new contact is registered. Contact(s): [sip:201@10.10.151.38:5063 / 201]
    07-Feb-2017 20:39:00.543   [CM102001]: Authentication failed for AuthFail Recv Req REGISTER from 10.0.0.65:5060 tid=06fad0643ffe739a3aab9e5ae5084711 Call-
    Via: SIP/2.0/UDP 10.0.0.65:5060;branch=z9hG4bK06fad0643ffe739a3aab9e5ae5084711
    Max-Forwards: 70
    CSeq: 53696 REGISTER
    Expires: 1200
    username="104",realm="3CXPhoneSystem",uri="sip:10.10.150.20",nonce="414d535c0eaaf9a471:88dbf46cf1e2df850e11e02745aa2d60",response="bc53c02058d2be650949711de3188c47",al
    gorithm=MD5
    Supported: timer
    Content-Length: 0
    07-Feb-2017 20:39:00.543   [Auth] Provided response (bc53c02058d2be650949711de3188c47 doesn't match calc. (f9f9d09a8c7283a29377d93d6364f9a3)
    07-Feb-2017 20:38:30.386   [CM102001]: Authentication failed for AuthFail Recv Req REGISTER from 10.0.0.65:5060 tid=1bff0962ca3626b0bb41330af5968fce Call-
    Via: SIP/2.0/UDP 10.0.0.65:5060;branch=z9hG4bK1bff0962ca3626b0bb41330af5968fce
    Max-Forwards: 70
    CSeq: 53694 REGISTER
    Expires: 1200
    username="104",realm="3CXPhoneSystem",uri="sip:10.10.150.20",nonce="414d535c0eaaf98688:06c0f15f472acbe4a1a0ec6a8b59dad6",response="f65c43877478f2fab2415c50d02d9874",al
    gorithm=MD5
    Supported: timer
    Content-Length: 0
    07-Feb-2017 20:38:30.386   [Auth] Provided response (f65c43877478f2fab2415c50d02d9874 doesn't match calc. (b9b8065eedf497237f67b2f90f0ae66d)
    07-Feb-2017 20:38:05.059   Leg L:5.1[Extn:195] is terminated: Cause: BYE from PBX
    07-Feb-2017 20:38:05.023   [CM503020]: Call(C:5): Normal call termination. Call originator: Extn:195. Reason: Terminated
    07-Feb-2017 20:38:05.023   L:5.1[Extn:195] failed to reach Line:10002>>5506, reason Not Acceptable HereReason Unknown
    07-Feb-2017 20:38:05.023   Leg L:5.2[Line:10002>>5506] is terminated: Cause: 401 Unauthorized/INVITE from 10.0.4.62:5060
    07-Feb-2017 20:38:05.023   Call to T:Line:10002>>5506@[Dev:sip:5000@10.0.4.62:5060] from L:5.1[Extn:195] failed, cause: Cause: 401 Unauthorized/INVITE from
    10.0.4.62:5060
    07-Feb-2017 20:38:04.867   [CM503003]: Call(C:5): Call to <sip:5506@10.0.4.62:5060> has failed; Cause: 401 Unauthorized/INVITE from 10.0.4.62:5060
    07-Feb-2017 20:38:04.664   [CM503025]: Call(C:5): Calling T:Line:10002>>5506@[Dev:sip:5000@10.0.4.62:5060] for L:5.1[Extn:195]
    07-Feb-2017 20:38:04.606   [CM503027]: Call(C:5): From: Extn:195 ("Test User" <sip:195@10.10.150.20:5060>)  to  T:Line:10002>>5506@[Dev:sip:5000@10.0.4.62:5060]
    07-Feb-2017 20:38:04.606   [CM503004]: Call(C:5): Route 2: from L:5.1[Extn:195] to T:Line:10002>>5506@[Dev:sip:5000@10.0.4.62:5060]
    07-Feb-2017 20:38:04.606   Line limit check: Current # of calls for line Lc:10002(@CUCM Trunk[<sip:5000@10.0.4.62:5060>]) is 0; limit is 10
    07-Feb-2017 20:38:04.606   [CM503026]: Call(C:5): Route 1 to PBXlineCUCM is not active (Busy/Not registered)
    07-Feb-2017 20:38:04.606   Call(C:5): from L:5.1[Extn:195]: There are no available outbound lines on Trunk 'PBXlineCUCM' at this time. First line: 10000
    07-Feb-2017 20:38:04.562   [CM303003]: There are no available outbound lines on gateway CUCM at this time. First line: Lc:10000(@CUCM[<sip:10000@:5060>])
    07-Feb-2017 20:38:04.562   Line limit check: Current # of calls for line Lc:10000(@CUCM[<sip:10000@:5060>]) is 0; limit is 10
    07-Feb-2017 20:38:04.562   Call(C:5): Call from Extn:195 to 5506 matches outbound rule 'Rule for CUCM'
    07-Feb-2017 20:38:04.561   [CM503001]: Call(C:5): Incoming call from Extn:195 to <sip:5506@10.10.150.20:5060>
    07-Feb-2017 20:38:04.561   NAT/ALG check:L:5.1[Extn:195] REQUEST 'INVITE' - basic check passed. No information for extended checks
    07-Feb-2017 20:38:00.284   [CM102001]: Authentication failed for AuthFail Recv Req REGISTER from 10.0.0.65:5060 tid=5f2a21d3573fc04a21623c2a771bd582 Call-
