Help with 3cx recognizeing analog phone
Discussion in '3CX Phone System - General' started by neulserik, Mar 4, 2010.
  1. neulserik
    Mar 4, 2010
    I have recently set up an analog phone through a handytone 486. It all works well however the 3cx console does not recognise the extension and I am haveing trouble transfering calls. Anyone have sugestions or links that may help me ???[/
    10,587
    253
    What does the 3Cx log look like when the extension first registers, when you first plug the power into the 486?
  3. neulserik
    Mar 4, 2010
    I did not check that. Should I ? Also if I use call assistant will this help softphone recognize analog as an extension represented in softphone console?
  4. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Yes the server activity log will help you understand what is going to wrong, also it will help to look at it when you make the transfer.
    For debugging purposes like these I recommend you put 3CX logging into verbose mode from Settings> Advanced > and set the logging level to verbose and restart the services of the system.
