HELP WITH CALL LOGS
Discussion in '3CX Phone System - General' started by ramon, Nov 28, 2007.
  1. ramon
    Sep 28, 2007
    8
    HI.
    THE HOUR WHEN THE CALLS WERE PLACED IS NOT CORRECT, IS DELAY 5 HOURS. I NEED TO KNOW HOW TO CHANGE THE HOUR. DOES 3CX HAS A TIME CLOCK?
    THANKS FOR YOUR HELP.
  2. Ralph
    Ralph Member
    Jun 28, 2007
    417
    Good evening
    I realize that this may be a silly question, but you never know. :D
    Have you checked the clock on the server on which 3CX is running?
  3. ramon
    Sep 28, 2007
    8
    Yes, i have. I know that 3CX takes the hour from the system clock but what i try to understand is why is delayed for 5 hours. Help please.
  4. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    Second silly question :oops:
    Are you saying that the Server has the correct time and 3CX is off by 5 hours?
    Or is both the Server & 3CX off by 5 hours?
  5. ramon
    Sep 28, 2007
    8
    Yes. The time on call logs in 3CX is off by 5 Hours.
  6. Ralph
    Ralph Member
    Jun 28, 2007
    417
    That is odd
    Just to make certain that I understand.
    The time on the server that 3CX is installed on is correct but the time on the 3CX call logs is off by 5 hours?
  7. ramon
    Sep 28, 2007
    8
    THAT'S RIGHT.
  8. Ralph
    Ralph Member
    Jun 28, 2007
    417
    Interesting
    Have you checked the clock setting on your phone or adapter?
    Also when you say call logs are you looking at the server log that you get when you click server status or the call log that you generate when you click Call Logs under Reports on the left side menu?
  9. ramon
    Sep 28, 2007
    8
    Hi.
    When i say call logs i'm making reference to the call log that i generate when i click Call Logs under Reports on the left side menu. And yes, i've checked the clock settings on my PATTON SN4924JS and is up to date; has the same time that the clock in the machine where is installed 3CX.
    Thanks for your help.
  10. Ralph
    Ralph Member
    Jun 28, 2007
    417
    hmmm
    This is a puzzler.
    Have you tried restarting the server and the 3CX service?
    When in doubt, reboot :D
  11. webguyz
    webguyz New Member
    Jul 19, 2007
    126
    Is the time zone on the servers system clock set correctly?
  12. ramon
    Sep 28, 2007
    8
    Yes is set correctly. My time zone is (GMT-07:00) Chihuhua, La paz, Mazatlan.
  13. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Just specify, How and where you did find this "wrong" time?
  14. ramon
    Sep 28, 2007
    8
    When i printed the call logs report of my extension, the hour when was placed the registered calls is wrong, isn't the real hour actually. For example if a placed a call from my extension to any number at 5:00 pm in the call logs report appears as if the call was placed at 10:00 pm.
    Thanks for your patience.
  15. Mori
    Mori New Member
    Mar 23, 2007
    223
    Heres a thougt..
    Try to offset system clock with 5 hours, and then see what 3cx says.. :)
