Help with call transfers.
Discussion in '3CX Phone System - General' started by sssputnik, May 13, 2010.
  1. sssputnik
    Apr 21, 2010
    25
    Our new 3CX system is working very well. However we have an issue with call transfers.
    I believe the issue may be down to mapping of SIP fields? (We are using a VoIP provider only).
    We are using Yealink phones with latest firmware. (T20 and T26 models) Latest 3CX version.
    If an external call comes in:
    If I do a Blind Transfer, (<TRAN>EXT<TRAN>) the caller ID comes through fine.
    If I do an announced transfer, (<TRAN>EXT# talk to extension <TRAN>) it doesn’t. Instead the EXT I am transferring FROM shows on the destination phone.
    I'd like the end recipients handset to show to original caller ID always, not just when a blind transfer happens.
    Any assistance on fields to look at etc, Reinvite etc seem to have no influence.
    Regards,
    Simon.
  2. sssputnik
    Apr 21, 2010
    25
    Logs of a call. ????'s to hide calling number.
    Please post all call logs in code and /code tags, this time it has been done for you - MFM
    Code:
    10:38:45.415  [CM503008]: Call(2243): Call is terminated
    10:38:38.728  [CM503008]: Call(2244): Call is terminated
    10:38:38.712  [CM505003]: Provider:[Amcom IPSystems] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:61894239000@172.20.4.30:5060]
    10:38:36.149  [CM503007]: Call(2244): Device joined: sip:1275@192.168.1.98:5062
    10:38:36.149  [CM503007]: Call(2244): Device joined: sip:1269@192.168.2.100:5062
    10:38:33.384  [CM505001]: Ext.1275: Device info: Device Identified: [Man: Yealink;Mod: T20;Rev: General] Capabilities:[reinvite, no-replaces, unable-no-sdp, no-recvonly] UserAgent: [Yealink SIP-T20P 9.43.0.50] PBX contact: [sip:1275@192.168.2.2:5060]
    10:38:33.384  [CM503002]: Call(2244): Alerting sip:1275@192.168.1.98:5062
    10:38:33.024  [CM503025]: Call(2244): Calling Ext:Ext.1275@[Dev:sip:1275@192.168.1.98:5062]
    10:38:32.977  [CM503004]: Call(2244): Route 1: Ext:Ext.1275@[Dev:sip:1275@192.168.1.98:5062]
    10:38:32.977  [CM503010]: Making route(s) to <sip:1275@192.168.2.2>
    10:38:32.977  [CM505001]: Ext.1269: Device info: Device Identified: [Man: Yealink;Mod: T26;Rev: General] Capabilities:[reinvite, no-replaces, unable-no-sdp, no-recvonly] UserAgent: [Yealink SIP-T26P 6.43.0.50] PBX contact: [sip:1269@192.168.2.2:5060]
    10:38:32.962  [CM503001]: Call(2244): Incoming call from Ext.1269 to <sip:1275@192.168.2.2>
    10:38:26.055  [CM503007]: Call(2243): Device joined: sip:1269@192.168.2.100:5062
    10:38:26.055  [CM503007]: Call(2243): Device joined: sip:61894239000@amcomvoice.ipsystems.com.au:5060
    10:38:24.680  [CM505001]: Ext.1269: Device info: Device Identified: [Man: Yealink;Mod: T26;Rev: General] Capabilities:[reinvite, no-replaces, unable-no-sdp, no-recvonly] UserAgent: [Yealink SIP-T26P 6.43.0.50] PBX contact: [sip:1269@192.168.2.2:5060]
    10:38:24.680  [CM503002]: Call(2243): Alerting sip:1269@192.168.2.100:5062
    10:38:24.243  [CM503025]: Call(2243): Calling Ext:Ext.1269@[Dev:sip:1269@192.168.2.100:5062]
    10:38:24.196  [CM503004]: Call(2243): Route 1: Ext:Ext.1269@[Dev:sip:1269@192.168.2.100:5062]
    10:38:24.196  [CM503010]: Making route(s) to <sip:1269@192.168.2.2:5060>
    10:38:24.196  [CM505003]: Provider:[Amcom IPSystems] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:61894239000@172.20.4.30:5060]
    10:38:24.180  [CM503001]: Call(2243): Incoming call from ??????????@(Ln.10002@Amcom IPSystems) to <sip:1269@192.168.2.2:5060>
    10:38:24.180  [CM503012]: Inbound office hours rule (Simon Shaw) for 10002 forwards to DN:1269
  3. StefanW
    Jun 2, 2009
    1,210
    85
    at the moment you will be not able to fix it. The Reffer or screen refresh is not more read by the phone.
    V9 addresses this issue with many phones with changing the call take over to re-invites with replaces. this should work then also for phones what dont understand it before.
  4. sssputnik
    Apr 21, 2010
    25
    OK thanks Stefan. Looking forward to the new version.
