Help with Fax
Discussion in '3CX Phone System - General' started by tazpro, Nov 21, 2008.
  1. tazpro
    Sep 23, 2008
    5
    I have 2 FX0 lines coming into a Grandstream 4104 that are answered by an autoattendant. I have 3cx free edition.
    I need to add 1 fax machine into the office and i cannot get another line from the PSTN provider for another 3 months. can i share 1 of the FXO lines as a secondary line and fax line?
    what is the best way to add an analog fax machine?
    Can T.38 fax work with 3cx free?
  2. justin
    Feb 20, 2008
    79
    With free version you would need to have a prompt setup. Something like "Press 1 for Sales, 2 for technical support or hold to send a fax", then set the wait time to 2 or 3 seconds, then have it forward the call to the extension setup with the fax machine :)
