help with inbound calls not working outbound works fine
Discussion in '3CX Phone System - General' started by hanksmith5, Jan 6, 2009.
  1. hanksmith5
    Jan 6, 2009
    hello I am using voipyourlife with 3cx ip pbx 7
    my outbound works fine I can dial extention to extention okay how ever when I dial inbound eg from outside like my cell phone or anty other number to my pbx it won't go threw it rings once, then gives me a busy signal. I have my did set to my phone number and a * at the end. I also have it set to go to 100 during office hours and during non office hours. any ideas what I got mis configured? thanks Hank
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,994
    304
    Troubleshooting an unsupported VoIP provider is a lot of work and requires SIP knowledge. Most of the times the provider in question is not SIP compliant. This troubleshooting is beyond the scope of these free user to user forums.
    Its easier to use a support VoIP provider (which are listed in the interface), or else to at least use a community supported one. You can find a list here:
    http://wiki.3cx.com/Home/voip-provider-configuration/voip-provider-templates
    These are being used by 3CX users.
    In addition you might want to review this thread which is less structured but also includes more feedback from users about particular VoIP providers:
    http://www.3cx.com/forums/working-voip-providers-5011-45.html
