Help with installion
Discussion in '3CX Phone System - General' started by cleo1552, Mar 6, 2008.
  1. cleo1552
    Mar 6, 2008
    Hello
    I am total new to this thing. ANyway i down loaded the 3cx free version as well as the 3cx client version. I have optimum online for a voip provider. When i go to the program wizaed on the free version the left hand side ask for provider; sipgate, voipgate, etc,etc. playing around i choose voipgate, i do not get any dial tone nothing, what am i doing wrong here
    teresa
  2. darrellchapman
    Nov 26, 2007
    268
    teresa,
    I would like to help you however I definitely need more info. What does or doesn't work? How far have you gone in installing/configuring the server.
    Have you successfully installed 3CX server? If so, what is the IP address of that machine?
    Have you added extensions? If not, do this first.
    Have you setup a 3CX client or desk phone? If not, do this too.
    Setting up a provider is the last thing I would do. You need to make the server and an extension are configured correctly before you can successfully test with a provider.
    Best Regards,
    Darrell Chapman
  3. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    Darrell is correct. Create a couple extensions and get those working. Setup voicemail and make sure that works. Once that is done then add a voip providor. If you don't see yours listed, then use the generic one and use the settings they give you.
    You will also have to create an outbound rule to dial out. Dial 9 and then the number.
    Are your phones registered to the server ok?
  4. landfiets
    landfiets New Member
    Jul 17, 2007
    242
    Hi, When you have Optimum and are just playing around with another, I think something goes wrong.
    As what I understand you should check out there..... generic provider and fillout all the details of your optimum provider.
    Offcourse you need as said the internal phones to be configured. Make 2 so you can try to call eachother on the internal line.
