Help with Ip phone
Discussion in '3CX Phone System - General' started by Anonymous, Dec 21, 2006.
  1. Anonymous
    Anonymous Guest
    Hello, I have 7 IP phone (4 Cisco 7912 and 3 Cisco 7920 wireless) and I want to connect to a Siemens Hipath PBX. How can I do?
  2. Watashi_FR
    Dec 5, 2006
    63
    Depending on which HiPath you have, you can connect them directly to it using SIP.
  3. Anonymous
    Anonymous Guest
    hipath does not have voip onboard. can i use a linksys spa 3000 for each ip phone ?
    1 linksys spa 3000 for each ip phone, connected to an analog port of Hipath and every LAN port of Linksys connected to a switch??????
  4. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    2,007
    309
    You cant connect CISCO phones to SIEMENS PBXs....
  5. Watashi_FR
    Dec 5, 2006
    63
    From the Siemens website, concerning the HiPath 3000 v6.0:
