help with media centre videophone
Discussion in '3CX Phone System - General' started by apcs, Mar 15, 2008.
  1. apcs
    Mar 10, 2008
    8
    I am trying to setup my currently trying to setup my livingroom pc, running windows vista ultimate edition. I am tring to install vista media centre video phone http://vistamcvideophone.oabsoftware.nl/ as an external extension. i am having problems connecting to my 3cx server.
    i can connect from this pc using x-lite & the 3cx softphone
    i can also use the videophone software to connect to sipphone.com
    i cannot connect the videophone to my 3cx server
    the settings i can edit on the software package are as follows
    standard settings
    Here you can enter:
    * Your display name, that will be shown to people you're going to call.
    * The username (or in most cases: the SIP phone number) of your SIP account.
    * The password for your SIP account.
    * The name of the (proxy) server of your SIP service.
    If required, you can also enter additional settings in the "Advanced" tab:
    Here you can enter:
    * The name of the SIP registrar server of your SIP service.
    * The name of the SIP realm of your SIP service.
    * The protocol you want to use for connecting to your SIP server.
    (you probably don't want to change this)
    * The authentication method you want to use when connecting to your SIP server.
    (you probably don't want to change this either)
    any help with setup would be appreciated. alternatively another soft phone that has a media centre interface.
    Thanks in advance
    Andy
  2. apcs
    Mar 10, 2008
    8
    anyone with help on this i can connect other softphones to 3cx and i can connect this softphone to directly to my sip provider.
    please any advice would be gratefull
    Cheers
    Andy
  3. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    question,
    What do you mean "cannot connect"?
    Do you have problems related to phone registration on PBX or problems related to place/receive call?
    You can post PBX log here (Server status page). It will provide some more information about interoperability issues.
  4. apcs
    Mar 10, 2008
    8
    the video phone software will not connect to my server at all though it is very vague and simply says cannot loggon failed.
    the server logs show the following when i try to connect
    18:42:18.983 ExtnCfg::updateContact [CM504002]: Ext.100: a contact is unregistered. Contact(s): []
    18:40:09.956 ExtnCfg::updateContact [CM504001]: Ext.100: new contact is registered. Contact(s): [sip:100@84.69.115.232:50042;rinstance=7b64140522c98dc1/100]
    18:40:09.175 ExtnCfg::updateContact [CM504002]: Ext.100: a contact is unregistered. Contact(s): []
    18:40:08.034 ExtnCfg::updateContact [CM504001]: Ext.100: new contact is registered. Contact(s): [sip:100@192.168.1.42:50042;rinstance=5a519688440a8872/100]
    was hoping somone had had previous experience with this program
    Cheers andy
    ps. this happens when i try to connect via lan as well as remotely
  5. SY
    3CX Support
    Jan 26, 2007
    1,825
    Do they have a version of phone that works on Windows XP?
    I will be glad to check its functionality.
  6. apcs
    Mar 10, 2008
    8
  7. SY
    3CX Support
    Jan 26, 2007
    1,825
    It is a result of my first try to setup it... I hope I'm providing a very clear bug report ;)
    Error
    Unable to execute file:
    C:\WINDOWS\eHome\RegisterMCEApp.exe
    CreateProcess failed; code 2.
    The system cannot find the file specified
    OK
    Then...
    Error
    C:\WINDOWS\Microsoft.NET\Framework\v1.0.3705\regasm
    OK
  8. apcs
    Mar 10, 2008
    8
    well thanks for trying.
    seems you are not running xp mce. which is why you recieve the error when installing.
    anyone else who has vista or xp mce who can try to test this i would be very gratefull
    thanks
    andy
