Help with nexvortx, 3cx is "Reject incoming calls"
Discussion in '3CX Phone System - General' started by Mirzab, Nov 4, 2007.
  1. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    That looks a bit strange. Can you give info on setup? Is 66.23.129.253 the 3CX? Is this a LAN address or WAN? That sort of stuff.
  2. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
  3. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    I use (and promote nexVortex). Are you using version 3 or 4?
    version 3 I had no problems at all.
    version 4 I am as you can see from the above link.
    nV is just starting to get 3CX tested in house but they do support it.
  4. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    Which version are you using 3 or 4?
    With 3 it's easy to setup. 4 seems to be a little more work (still trying to get it myself) but doable. And I'm sure it will be better with the real release of 4.
    What OS?
    Did you check your firewall ports?
    Did you put in all the correct nV registration info?
    What is your inbound rule for that line? Did you point it to an extension that is registered and working or did you point it to DR?
    Deerfield support should really be helping you since you paid for it from them. 3CX and nV work fine together - I have several clients running both with no issues at all.
