Help with Patton SmartNode 4634
Discussion in '3CX Phone System - General' started by Dubs, Apr 17, 2007.
  1. Dubs
    Apr 17, 2007
    Hi there,
    I am having trouble getting this box to work. I have read the Patton FAQ on this site, but still cannot seem to get it to work.
    We are trying to route our calls in and out of ISDN (BRI in the UK) via the SmartNode 4634. We also want DDI and Caller ID passed on if possible.
    3CX will not register the VOIP gateway. Here is a copy of my config: -
    # SN4634/3BIS/UI #
    # R3.20 2006-10-04 H323 SIP BRI #
    # 1970-01-01T00:56:03 #
    # Generated configuration file #
    cli version 3.20
    dns-relay
    webserver port 80 language en
    sntp-client
    sntp-client server primary 129.132.2.21 port 123 version 4
    system
    ic voice 0
    low-bitrate-codec g729
    profile napt NAPT_WAN
    profile ppp default
    profile tone-set default
    profile voip default
    codec 1 g711alaw64k rx-length 20 tx-length 20
    codec 2 g711ulaw64k rx-length 20 tx-length 20
    profile pstn default
    profile sip default
    profile dhcp-server DHCPS_LAN
    network 192.168.0.0 255.255.255.0
    include 1 192.168.0.10 192.168.0.99
    lease 2 hours
    default-router 1 192.168.0.1
    domain-name-server 1 192.168.0.1
    profile aaa default
    method 1 local
    method 2 none
    context ip router
    interface WAN
    ipaddress dhcp
    use profile napt NAPT_WAN
    tcp adjust-mss rx mtu
    tcp adjust-mss tx mtu
    interface LAN
    ipaddress 192.168.1.2 255.255.255.0
    interface wan
    ipaddress unnumbered
    interface eth0
    ipaddress 192.168.0.254 255.255.0.0
    context cs switch
    interface sip sip
    bind gateway 3cxpbx
    service default
    route call dest-interface sip
    interface sip SIP-IF
    bind gateway 3cxpbx
    service default
    context cs switch
    no shutdown
    gateway sip 3cxpbx
    bind interface eth0 router
    service default
    authentication 30002 password iQAbdwbb86U= encrypted
    default-server 192.168.1.4 loose-router
    registration-lifetime 1200
    registrar 192.168.1.4
    gateway sip 3cxpbx
    no shutdown
    port ethernet 0 0
    medium auto
    encapsulation ip
    bind interface WAN router
    no shutdown
    port ethernet 0 1
    medium auto
    encapsulation ip
    bind interface LAN router
    no shutdown
    port bri 0 0
    clock auto
    encapsulation q921
    q921
    protocol pmp
    uni-side auto
    encapsulation q931
    q931
    protocol dss1
    uni-side user
    port bri 0 0
    shutdown
    port bri 0 1
    clock auto
    encapsulation q921
    q921
    protocol pmp
    uni-side auto
    encapsulation q931
    q931
    protocol dss1
    uni-side net
    port bri 0 1
    shutdown
    port bri 0 2
    clock auto
    encapsulation q921
    q921
    protocol pmp
    uni-side auto
    encapsulation q931
    q931
    protocol dss1
    uni-side net
    port bri 0 2
    shutdown
    And here is a link to the manual: -
    http://www.patton.com/manuals/SCG-r320.pdf
    All the is completely new to me, so I am sure it is probably something very simple indeed.
    I have also logged a call with Patton, and will post any responses here for the benefit of the community.
    Any help greatly appreciated!
    David
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,915
    221
    Hi David,
    Just to doublecheck: Have you followed the instructions in the FAQ to the letter? Via the command line?
    http://www.3cx.com/support/patton-smartnode.html
    Because this way it should work.
    If you post the server status log it will help to see what the problem is during registration.
  3. Dubs
    Apr 17, 2007
    Well, I've definately tried the FAQ a few times, but 3cx will still not use this route. The PSTN line is registered OK, and the SmartNode also reports that it is registered, so this seems OK. However, when we try to route a call through to the VOIP gateway, it times out. Here is a server log when we try to make a call: -
    09:13:55.578 CallConf::Rejected Call (C:2E) is rejected: Destination is not answering
    09:13:55.578 StratInOut::eek:nCancel Call from Ext.115 to 100 has been terminated; reason: Request Timeout
    09:13:23.359 CallConf::eek:nIncoming Incoming call from Ext.115 to sip:9100@192.168.1.4
    We have an outgoing rule which routes calls beginning with 9 to the PSTN line and a transform mask of r.
    The colour of the PSTN line does not change from green, so it looks like it's not even trying to go via this route.
    Any ideas?
    David
    P.S. Here is the new config from Patton: -
    # SN4634/3BIS/UI #
    # R3.21 2007-03-23 H323 SIP BRI #
    # 2007-04-27T16:03:32 #
    cli version 3.20
    dns-client server 192.168.1.1
    dns-relay
    sntp-client
    system
    ic voice 0
    profile ppp default
    profile call-progress-tone UK_Dialtone
    play 1 5000 350 0 440 0
    profile call-progress-tone UK_Alertingtone
    play 1 400 400 0 450 0
    pause 2 200
    play 3 400 400 0 450 0
    pause 4 2000
    profile call-progress-tone UK_Busytone
    play 1 400 400 0
    pause 2 400
    profile tone-set UK
    map call-progress-tone dial-tone UK_Dialtone
    map call-progress-tone ringback-tone UK_Alertingtone
    map call-progress-tone busy-tone UK_Busytone
    map call-progress-tone release-tone UK_Busytone
    map call-progress-tone congestion-tone UK_Busytone
    profile sip default
    network 192.168.1.0 255.255.255.0
    include 1 192.168.1.10 192.168.1.99
    lease 2 hours
    default-router 1 192.168.1.1
    domain-name-server 1 192.168.1.1
    profile aaa default
    method 1 local
    method 2 none
    context ip router
    interface WAN
    ipaddress dhcp
    interface LAN
    context ip router
    route 0.0.0.0 0.0.0.0 192.168.1.1 0
    context cs switch
    routing-table called-e164 RT_FROM_ISDN
    route default dest-interface PBX
    interface isdn 3CX0
    route call dest-table RT_FROM_ISDN
    use profile tone-set UK
    interface isdn 3CX1
    interface sip PBX
    bind gateway GW_PBX
    service default
    route call dest-service HG_ISDN
    remote 192.168.1.4
    service hunt-group HG_ISDN
    drop-cause normal-unspecified
    drop-cause no-circuit-channel-available
    drop-cause network-out-of-order
    drop-cause temporary-failure
    drop-cause switching-equipment-congestion
    drop-cause access-info-discarded
    drop-cause circuit-channel-not-available
    drop-cause resources-unavailable
    route call 1 dest-interface 3CX0
    route call 2 dest-interface 3CX1
    context cs switch
    no shutdown
    gateway sip GW_PBX
    service default
    defaultserver manual 192.168.1.4 loose-router
    registration manual 192.168.1.4 use-default-server
    user 10001 authenticate password iQAbdwbb86U= encrypted register default
    gateway sip GW_PBX
    no shutdown
    port ethernet 0 0
    medium auto
    encapsulation ip
    no shutdown
    port ethernet 0 1
    medium auto
    encapsulation ip
    no shutdown
    port bri 0 0
    clock auto
    encapsulation q921
    q921
    protocol pmp
    uni-side auto
    encapsulation q931
    q931
    protocol dss1
    uni-side user
    encapsulation cc-isdn
    bind interface 3CX0 switch
    port bri 0 0
    no shutdown
    port bri 0 1
    clock auto
    encapsulation q921
    q921
    protocol pmp
    uni-side auto
    encapsulation q931
    q931
    protocol dss1
    uni-side net
    bind interface 3CX1 switch
    port bri 0 1
    no shutdown
    port bri 0 2
    clock auto
    encapsulation q921
    q921
    protocol pmp
    uni-side auto
    encapsulation q931
    q931
    protocol dss1
    uni-side net
    port bri 0 2
    shutdown
  4. Nick Galea
    Jun 6, 2006
    1,915
    221
    Well post a sample configuration for the patton gateway early next week.
    However i noticed you named the internal line for the pattong gateway to 100? By default thats 10000. 100 is not possible - I suggest sticking to the defaults.
  5. depri
    May 9, 2007
    Help with Patton SN5634
    I hope I can find some help here for my problem.
    Anyway my problem is very simple, but,...ok If I dial from ISDN phone to out -outgoing call everything is ok, but for incomming calls I have a problem. I get ring tone on Asub but no ringging ob ISDN phone, no connection.Could anyone please tell me what might be a problem for this case.thx
    I am new in these area and I'm just getting to know all the secrets arount patton.
    Any ideas,
    Thanks Mik
    ps:and the config ;
    # SN4634/3BIS/UI #
    # 2007-05-09T08:53:31 #
    cli version 3.20
    operator admin password v+SdstnPq74= encrypted
    dns-relay
    system
    ic voice 0
    profile ppp default
    profile call-progress-tone defaultDialtone
    play 1 700 425 -12
    pause 2 800
    play 3 200 425 -12
    pause 4 300
    profile call-progress-tone defaultAlertingtone
    play 1 1000 425 -12
    pause 2 4000
    profile call-progress-tone defaultBusytone
    play 1 500 425 -12
    pause 2 500
    fax transmission 1 bypass g711alaw64k
    profile sip default
    lease 2 hours
    profile aaa default
    method 1 local
    method 2 none
    context ip router
    interface WAN
    ipaddress 172.15.0.5 255.255.0.0
    icmp redirect accept
    interface LAN
    ipaddress 192.168.1.1 255.255.255.0
    context ip router
    dhcp-server use DHCPS_LAN
    route 0.0.0.0 0.0.0.0 172.15.0.1 0
    context cs switch
    routing-table called-e164 RTABLE
    route T dest-interface SIP_P
    mapping-table called-e164 to called-e164 mapping
    map 49200 to 49200
    interface isdn ISDN_P
    route call dest-interface SIP_P
    display emit
    dtmf-dialing
    isdn-date-time
    caller-name
    interface sip SIP_P
    bind gateway SIP-P
    service default
    route call dest-interface ISDN_P
    early-disconnect
    context cs switch
    no shutdown
    gateway sip SIP-P
    transaction-timeout invite 60
    penalty-box-time 600
    service default
    domain 172.18.0.2
    realm 172.18.0.2
    default-server 172.18.0.2 5060 strict-router
    registrar 172.18.0.2 5060
    user 338618 display-name P
    gateway sip SIP-P
    no shutdown
    port ethernet 0 0
    medium auto
    encapsulation ip
    no shutdown
    port ethernet 0 1
    medium auto
    encapsulation ip
    no shutdown
    port bri 0 0
    clock auto
    encapsulation q921
    q921
    protocol pmp
    uni-side auto
    encapsulation q931
    q931
    protocol dss1
    uni-side user
    port bri 0 0
    shutdown
    port bri 0 1
    clock auto
    encapsulation q921
    power-feed
    q921
    permanent-layer2
    protocol pmp
    uni-side auto
    encapsulation q931
    q931
    protocol dss1
    uni-side net
    bind interface ISDN_P switch
    port bri 0 1
    no shutdown
    port bri 0 2
    clock auto
    encapsulation q921
    q921
    permanent-layer2
    protocol pmp
    uni-side net
    encapsulation q931
    q931
    protocol dss1
    uni-side net
    port bri 0 2
    shutdown
    SN4634/3BIS/UI
