Help with SIPphone.com not registering
Discussion in '3CX Phone System - General' started by deruig, Dec 2, 2007.
  1. deruig
    Dec 2, 2007
    I am new to all this.
    I am trying to connect to my VOIP provider, SIPphone.com, but the registration keeps failing.
    I have found at lease 6 posts of people saying that they connected to SIPphone.com successfully.
    I have tried 3.1 and 5 of the free version of 3CX.
    I can successfully conect to my provider with my Grandstream 286 and X-Lite so I know my setting are good.
    When I run the firewall test it passess. I even tried openning the ports on my router.
    I am sure that I am doing something silly that one of you can catch.
    Yesterdat I was getting a error 408 (Timeout). Today I am getting a 476 Authorization failed.
    SIPphone.com states:
    Any SIP compatible piece of hardware should be compatible with the Gizmo service. However, we do not provide support for those other than those that we have sold in the past.
    To configure a device you need the following information:
    SIP Proxy: proxy01.sipphone.com:5060
    STUN server: stun01.sipphone.com:3478
    Username: Your SIP number, found by dialing ** in Gizmo
    Password: Your password
    Codecs: iLBC, GSM, g711a, and g711u (Gizmo Project uses other codecs as well, but you won't find them in your hardware settings)
    Note: If your device includes setup fields for an "Outbound Proxy" leave all of those fields blank. Gizmo Project does not provide an outbound proxy service and your device won't be able to connect to our network if you put anything into those fields.
    Here Is a sample of the log.
    15:21:54.146|ClientRegistration.cxx(180)|Trace5|Resip|>>:Removing binding
    15:21:54.146|.\Registrar.cpp(451)|Trace5|Registrar|ClientRegs::eek:nRemoved:Removed registration for []
    15:22:29.106|TuSelector.cxx(70)|Trace5|Resip|>>:Stats message
    15:23:29.153|TuSelector.cxx(70)|Trace5|Resip|>>:Stats message
    15:23:29.673|.\CallEvents.cpp(78)|Trace5||FireStatusEvent:Fire event: Undefined; DN 10000
    15:23:29.673|.\ExtLine.cpp(325)|Log2|Endpoints|ExtLine::Register:[CM110001] Use External IP for device line registration DN='10000' device='SipPhone'
    15:23:29.673|.\ExtLine.cpp(366)|Log2|Endpoints|ExtLine::Register:[CM110004] Send registration for "17476677848"<sip:17476677848@proxy01.sipphone.com>
    15:23:29.824|DialogUsageManager.cxx(1190)|Trace5|Resip|>>:Got: SipResp: 476 tid=9f61ad2daa546769 cseq=REGISTER / 1 from(wire)
    15:23:29.824|.\Registrar.cpp(419)|Trace5|Registrar|ClientRegs::eek:nFailure:Reg. failure: h=119; code=476
    15:23:29.824|.\Registrar.cpp(422)|Trace5|Registrar|ClientRegs::eek:nFailure:ADS: hReg=909522740; attempt=0
    15:23:29.824|.\Registrar.cpp(424)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113006] Registration of sip:17476677848@proxy01.sipphone.com has failed; reason=Not Authorized. (NA-1)
    15:23:29.824|.\CallEvents.cpp(78)|Trace5||FireStatusEvent:Fire event: Undefined; DN 10000
    15:23:29.824|.\Registrar.cpp(438)|Log2|Registrar|ClientRegs::eek:nFailure:[CM113010] Next registration will be attempted in 10 minutes
  2. deruig
    Dec 2, 2007
    Further Information
    I have done some more research and have the the requests are different from 3CX to X-Lite
    3CX is using UPD, X-Light is using TCP
    Here is the X-Light data:
    REGISTER sip:proxy01.sipphone.com SIP/2.0
    Via: SIP/2.0/TCP 192.168.1.101:45146;branch=z9hG4bK-d87543-377d1413c327d907-1--d87543-;rport
    Max-Forwards: 70
    Contact: <sip:17476010423@192.168.1.101:45146;rinstance=55b52e3168637f0e;transport=TCP>;expires=0
    To: "Dan's Softphone"<sip:17476010423@proxy01.sipphone.com>
    From: "Dan's Softphone"<sip:17476010423@proxy01.sipphone.com>;tag=1767b331
    Call-ID: MTdiMzY2NmZlMDlmMGFiMzAyYWJmZWY4ZDAwNmE1OGM.
    CSeq: 3 REGISTER
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, NOTIFY, MESSAGE, SUBSCRIBE, INFO
    User-Agent: X-Lite release 1011s stamp 41150
    Authorization: Digest username="17476010423",realm="proxy01.sipphone.com",nonce="4755b479c0191d44563403cd88d8c0484587589f",uri="sip:proxy01.sipphone.com",response="e4638cc5966f97183564ebd551221915",algorithm=MD5
    Content-Length: 0
    Here is the 3CX log:
    15:44:04.039|TimerQueue.cxx(85)|Debug8|Resip|::ResipLogger:Adding timer: Timer F tid=a7104f12996fa239 ms=32000
    15:44:04.039|DnsResult.cxx(186)|Debug8|Resip|::ResipLogger:DnsResult::lookup sip:17476677848@proxy01.sipphone.com;transport=UDP
    15:44:04.209|TimerQueue.cxx(85)|Debug8|Resip|::ResipLogger:Adding timer: Timer E1 tid=a7104f12996fa239 ms=500
    15:44:04.209|TransportSelector.cxx(525)|Debug8|Resip|::ResipLogger:Looked up source for destination: [ V4 198.65.166.131:5060 UDP target domain=proxy01.sipphone.com connectionId=0 ] -> [ V4 192.168.1.101:0 UDP target domain=proxy01.sipphone.com connectionId=0 ] sent-by= sent-port=0
    15:44:04.209|TransportSelector.cxx(971)|Debug8|Resip|::ResipLogger:findTransportBySource([ V4 192.168.1.101:0 UDP target domain=proxy01.sipphone.com connectionId=0 ])
    15:44:04.209|TransportSelector.cxx(1072)|Debug8|Resip|::ResipLogger:findTransport (any port, specific interface) => Transport: [ V4 192.168.1.101:5060 UDP target domain=unspecified connectionId=0 ] on 192.168.1.101
    15:44:04.209|TransportSelector.cxx(766)|Debug8|Resip|::ResipLogger:Transmitting to [ V4 198.65.166.131:5060 UDP target domain=proxy01.sipphone.com received on: Transport: [ V4 192.168.1.101:5060 UDP target domain=unspecified connectionId=0 ] on 192.168.1.101 connectionId=0 ] tlsDomain= via [ V4 192.168.1.101:5060 UDP target domain=proxy01.sipphone.com connectionId=0 ]REGISTER sip:proxy01.sipphone.com:5060 SIP/2.0
    Via: SIP/2.0/UDP 192.168.1.101:5060;branch=z9hG4bK-d87543-a7104f12996fa239-1--d87543-;rport
    Max-Forwards: 70
    Contact: <sip:17476677848@68.191.211.108:5060;rinstance=d5075413925b2a0c>
    To: "17476677848"<sip:17476677848@proxy01.sipphone.com:5060>
    From: "17476677848"<sip:17476677848@proxy01.sipphone.com:5060>;tag=1a510f7d
    Call-ID: MTVkNTYyNDU3ZGZmY2U2ZGI2NGFmZjFhNTVmOWUzNTM.
    CSeq: 1 REGISTER
    Expires: 3600
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO
    User-Agent: 3CXPhoneSystem 5.0.3563.0
    Content-Length: 0
    15:44:04.209|Transport.cxx(209)|Debug8|Resip|::ResipLogger:Adding message to tx buffer to: [ V4 198.65.166.131:5060 UDP target domain=proxy01.sipphone.com received on: Transport: [ V4 192.168.1.101:5060 UDP target domain=unspecified connectionId=0 ] on 192.168.1.101 connectionId=0 ]
    15:44:04.279|Transport.cxx(259)|Debug8|Resip|::ResipLogger:incoming from: [ V4 198.65.166.131:5060 UDP target domain=unspecified received on: Transport: [ V4 192.168.1.101:5060 UDP target domain=unspecified connectionId=0 ] on 192.168.1.101 connectionId=0 ]
    15:44:04.279|DnsResult.cxx(177)|Debug8|Resip|::ResipLogger:Whitelisting proxy01.sipphone.com(1): 198.65.166.131
    15:44:04.279|dns\RRVip.cxx(129)|Debug8|Resip|::ResipLogger:updating an existing vip: 198.65.166.131 with 198.65.166.131
    15:44:04.279|TransactionState.cxx(1721)|Debug8|Resip|::ResipLogger:Send to TU: TU: DialogUsageManager size=0 SIP/2.0 476 Not Authorized. (NA-1)
    Via: SIP/2.0/UDP 192.168.1.101:5060;branch=z9hG4bK-d87543-a7104f12996fa239-1--d87543-;rport=15060;received=68.191.211.108
    To: "17476677848"<sip:17476677848@proxy01.sipphone.com:5060>;tag=21a483426c2cd5d9b85bffe6bba40a2e.a68e
    CSeq: 1 REGISTER
    Content-Length: 0
    P-Behind-NAT: Yes
    Any help would be appreciated
  3. deruig
    Dec 2, 2007
    Reply form SIPphone.com / GizmoProject.com
    Here is the reply form SIPphone.com / GizmoProject.com. :shock:
    SIPPhone Customer Care wrote:
    > I apologize but 3CX registration has been disabled. Sorry for the inconvenience.
    > Thank you for your patience.
    > Sincerely,
    > Gizmo Project Support
    > Ticket Details
    > Ticket ID: UQR-??????
    > Department: Technical Issues
    > Priority: Low
    > Status: Customer On Hold
    By the way, CallWithUs.com registered fine with 3CX.
  4. Moxi
    Feb 11, 2008
    6
    I can't use my GizmoProject account with 3CX too. It works with SPA3102 and x-lite, but fails to register with 3CX.
    Have you solved this?
    Here is my log:
    16:12:28.890|.\Registrar.cpp(494)|Log2|Registrar|ClientRegs::Register:[CM504003]: Sent registration request for 20000@SIPPHONE<br>
    16:12:30.390|.\Registrar.cpp(352)|Log2|Registrar|ClientRegs::eek:nFailure:[CM504005]: Registration failed for: 20000@SIPPHONE<br>
  5. landfiets
    landfiets New Member
    Jul 17, 2007
    243
    try to find out the IP adress of the proxy.
    Maybe that works to fill that out immediately
  6. Moxi
    Feb 11, 2008
    6
    It's not my configuration, i think it's something else. FWD (freeworlddialup) works setting just the same parameters.
  7. Zibri
    Jul 30, 2008
    Sipphone.com (gizmo5) has 3cx phonesystem blacklisted.
    I found a work-around:
    since the only way gizmo5 can know I'm using 3cx is the USER AGENT, I used a hex editor to change the user agent that 3cx sends.
    Effect:
    Now my 3cx phonesystem correctly connects to gizmo5 :)
  8. leejor
    10,594
    255
    Can you please explain how you go about changing the user agent in 3cx?
  9. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Really?
  10. janofsky
    Jun 13, 2009
    14
    Has anyone been able to register with Gizmo? If not how do you alter the user agent and where do I find it?
  11. zanthexter
    Jun 30, 2009
    11
    That's how you modify the User Agent in the current-as-of-this-writing 3CX v 7.1.7139.0 The string I used is actually the Gizmo5 windows client string :) It also worked with an X-Lite string and a generic Asterix PBX string.
    Without modifying the string, it wouldn't register.
    At this point Gizmo5 is sort of working:
    If I make a Gizmo to Gizmo call (2nd account to 1st account) it works just fine. (Incoming to 3CX or outgoing from 3CX)
    If I make an outbound toll free call it works just fine. (800-555-1212 is good for testing because lets you dictate lookups to the system.)
    if I make a Google Voice to Gizmo/3CX call, 3CX seems to answer, but all I hear is ringing on the phone I am dialing in on.
    If I make a Google Voice to Gizmo/X-Lite or Gizmo/GizmoSoftphone call, everything works fine. (So its not a Google Voice issue)
    Has me boggled at the moment how Gizmo/X-lite to Gizmo/3CX calls work, but Gizmo/Google Voice to Gizmo/3CX does not. It seems like some sort of "HI, I've answered the call" reply hasn't made it back to Google Voice. I'd blame it on Gizmo, but the two softphones work fine.
    Anyway, hopefully that at least answers your specific question.
  12. leejor
    10,594
    255
    What was the entire string, It looks like your snapshot was chopped off (no close bracket).
  13. Bindy Malinda
    Jul 10, 2009
    It’s been a while since there’s been much to cheer about in the free calls department with Asterisk. But today, to kick off the new school year, we have lots of good news and some simple tricks to add zillions of free phone numbers to your Asterisk repertoire. In fact, you’ll be able to call almost any non-AT&T cellphone or landline in the United States at no cost. Remember that when you buy your next cellphone!voip softphone
  14. leejor
    10,594
    255
    Never mind, saw the entire string up higher. Still having problems with audio on some calls. Working on it.
  15. gatornuke
    Jul 16, 2009
    How do you activate this "user agent"? I only dowloaded the voip phone software, and none of the other junk (call center and all that enterprise stuff). I'm having a heck of a time trying to configure this to work with my Gizmo5 account. What do they mean by extension? Proxy server? All i have is my user name and password, the @proxy01.sipphone.com, and a number that starts with 1747XXXXXXX.
    The stuff they ask for in the account settings section doesn't quite reconcile with the info i have. And where do i find this "user agent" Do i have to download more software to get this thing to work?
  16. leejor
    10,594
    255
    If you just downloaded and are using the VoIP soft phone then these settings apply to you. This all refers to the 3CX PBX and trying to get it to register with SipPhone. Are you having a problem getting the soft phone to register with them as well?
  17. janofsky
    Jun 13, 2009
    14
    I was able to register to Gizmo 5. Unfortunately, I could not get the audio (sending or receiving) to work. I changed the rtp prots to 5004 and 5005
    17:21:24.335 [CM501008]: *** Stopped Calls Controller thread ***
    17:21:24.194 [EC100007]: External application [ILENEold:0/InterfaceWindows] is disconnected:
    17:21:23.647 [EC000001]: Connection with configuration server is lost
    17:21:20.507 [EC100002] Connection with media server is lost
    17:21:15.553 *** Server shut down ***
    17:21:15.553 *** Server started ***
    17:21:15.553 *** Exit Listen ***
    17:21:14.491 [EC100004]: Connection with IVR server is lost
    17:21:14.116 [EC100006]: Connection with Conference server is lost
    17:21:10.538 [CM504002]: Ext.IVRForward: a contact is unregistered. Contact(s): []
    17:21:10.538 [CM504002]: Ext.EndCall: a contact is unregistered. Contact(s): []
    17:21:10.538 [CM504002]: Ext.80: a contact is unregistered. Contact(s): []
    17:21:10.382 [CM504002]: Ext.99: a contact is unregistered. Contact(s): []
    17:21:07.085 [CM504002]: Ext.*1: a contact is unregistered. Contact(s): []
    17:21:07.085 [CM504002]: Ext.*0: a contact is unregistered. Contact(s): []
    17:21:06.569 [EC100005]: Connection with Parking Orbit server is lost
    17:20:06.803 [MS105000] C:111.1: No RTP packets were received:remoteAddr=198.65.166.131:45854,extAddr=0.0.0.0:0,localAddr=192.168.163.75:7024
    17:20:05.991 [CM503008]: Call(111): Call is terminated
    17:19:57.803 [MS211000] C:111.3: 192.168.163.116:40004 is delivering DTMF using RTP payload (RFC2833). In-Band DTMF tone detection is disabled for this call segment.
    17:19:51.085 [CM503003]: Call(111): Call to sip:10@192.168.163.75:5060 has failed; Cause: 487 Request Terminated; from IP:192.168.163.90:1842
    17:19:50.960 [CM503007]: Call(111): Device joined: sip:10@192.168.163.116:1379;rinstance=e5568ee8c80b580a
    17:19:50.897 [CM503007]: Call(111): Device joined: sip:17474388373@proxy01.sipphone.com:5060
    17:19:45.600 [CM505001]: Ext.10: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXVoipPhone 4.0.9530.0] PBX contact: [sip:10@192.168.163.75:5060]
    17:19:45.600 [CM503002]: Call(111): Alerting sip:10@192.168.163.116:1379;rinstance=e5568ee8c80b580a
    17:19:45.491 [CM505001]: Ext.10: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXVoipPhone 4.0.9530.0] PBX contact: [sip:10@192.168.163.75:5060]
    17:19:45.491 [CM503002]: Call(111): Alerting sip:10@192.168.163.90:1842;rinstance=e27bdd4c25970999
    17:19:45.382 [CM503025]: Call(111): Calling Ext:Ext.10@[Dev:sip:10@192.168.163.116:1379;rinstance=e5568ee8c80b580a]
    17:19:45.319 [CM503025]: Call(111): Calling Ext:Ext.10@[Dev:sip:10@192.168.163.90:1842;rinstance=e27bdd4c25970999]
    17:19:45.288 [CM503004]: Call(111): Route 1: Ext:Ext.10@[Dev:sip:10@192.168.163.90:1842;rinstance=e27bdd4c25970999,Dev:sip:10@192.168.163.116:1379;rinstance=e5568ee8c80b580a]
    17:19:45.288 [CM503010]: Making route(s) to <sip:10@192.168.163.75:5060>
    17:19:45.178 [CM505003]: Provider:[Gizmo5 7474388373] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [SIPCallProxy1] PBX contact: [sip:17474388373@192.168.163.75:5060]
    17:19:45.147 [CM503001]: Call(111): Incoming call from Anonymous@(Ln.10003@Gizmo5 7474388373) to <sip:10@192.168.163.75:5060>
    17:19:45.085 [CM503012]: Inbound out-of-office hours rule (unnamed) for 10003 forwards to DN:10
    17:14:58.272 [CM506004]: STUN request to STUN server 198.65.166.165:3478 has timed out; used Transport: 192.168.163.75:5060
    17:14:52.225 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 198.65.166.165:3478 over Transport 192.168.163.75:5060
    16:55:16.335 [CM506004]: STUN request to STUN server 198.65.166.165:3478 has timed out; used Transport: 192.168.163.75:5060
    16:55:10.303 [CM506004]: STUN request to STUN server 198.65.166.165:3478 has timed out; used Transport: 192.168.163.75:5060
    16:55:04.225 [CM506004]: STUN request to STUN server 198.65.166.165:3478 has timed out; used Transport: 192.168.163.75:5060
    16:54:58.178 [CM506004]: STUN request to STUN server 198.65.166.165:3478 has timed out; used Transport: 192.168.163.75:5060
    16:54:52.116 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 198.65.166.165:3478 over Transport 192.168.163.75:5060
    16:34:52.022 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 198.65.166.165:3478 over Transport 192.168.163.75:5060
    16:14:51.975 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 198.65.166.165:3478 over Transport 192.168.163.75:5060
    15:54:51.913 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 198.65.166.165:3478 over Transport 192.168.163.75:5060
    15:34:51.819 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 198.65.166.165:3478 over Transport 192.168.163.75:5060
    15:14:57.772 [CM506004]: STUN request to STUN server 198.65.166.165:3478 has timed out; used Transport: 192.168.163.75:5060
    15:14:51.725 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 198.65.166.165:3478 over Transport 192.168.163.75:5060
    14:54:51.647 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 198.65.166.165:3478 over Transport 192.168.163.75:5060
    14:34:51.616 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 198.65.166.165:3478 over Transport 192.168.163.75:5060
    14:14:51.538 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 198.65.166.165:3478 over Transport 192.168.163.75:5060
    13:54:51.460 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 198.65.166.165:3478 over Transport 192.168.163.75:5060
    13:34:51.444 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 198.65.166.165:3478 over Transport 192.168.163.75:5060
    13:14:51.444 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 198.65.166.165:3478 over Transport 192.168.163.75:5060
    12:54:51.382 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 198.65.166.165:3478 over Transport 192.168.163.75:5060
    12:53:21.257 [CM504004]: Registration succeeded for: 10003@Gizmo5 7474388373
    12:53:02.132 [CM504004]: Registration succeeded for: 10002@Gizmo5 7472721772
    12:40:35.616 [CM504004]: Registration succeeded for: 10002@Gizmo5 7472721772
    12:39:25.163 [CM504004]: Registration succeeded for: 10003@Gizmo5 7474388373
    12:34:51.319 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 198.65.166.165:3478 over Transport 192.168.163.75:5060
    12:30:19.788 [CM504004]: Registration succeeded for: 10003@Gizmo5 7474388373
    12:29:51.991 [CM504004]: Registration succeeded for: 10002@Gizmo5 7472721772
    12:14:51.288 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 198.65.166.165:3478 over Transport 192.168.163.75:5060
    11:54:51.210 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 198.65.166.165:3478 over Transport 192.168.163.75:5060
    11:34:51.147 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 198.65.166.165:3478 over Transport 192.168.163.75:5060
    11:14:51.053 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 198.65.166.165:3478 over Transport 192.168.163.75:5060
    10:54:50.944 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 198.65.166.165:3478 over Transport 192.168.163.75:5060
    10:34:50.882 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 198.65.166.165:3478 over Transport 192.168.163.75:5060
    10:14:50.757 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 198.65.166.165:3478 over Transport 192.168.163.75:5060
    09:54:56.757 [CM506004]: STUN request to STUN server 198.65.166.165:3478 has timed out; used Transport: 192.168.163.75:5060
    09:54:50.678 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 198.65.166.165:3478 over Transport 192.168.163.75:5060
    09:35:02.725 [CM506004]: STUN request to STUN server 198.65.166.165:3478 has timed out; used Transport: 192.168.163.75:5060
    09:34:56.663 [CM506004]: STUN request to STUN server 198.65.166.165:3478 has timed out; used Transport: 192.168.163.75:5060
    09:34:50.600 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 198.65.166.165:3478 over Transport 192.168.163.75:5060
    09:14:56.585 [CM506004]: STUN request to STUN server 198.65.166.165:3478 has timed out; used Transport: 192.168.163.75:5060
    09:14:50.475 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 198.65.166.165:3478 over Transport 192.168.163.75:5060
    08:54:50.382 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 198.65.166.165:3478 over Transport 192.168.163.75:5060
    08:34:50.257 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 198.65.166.165:3478 over Transport 192.168.163.75:5060
    08:22:27.882 [CM504004]: Registration succeeded for: 10002@Gizmo5 7472721772
    08:22:25.772 [CM504004]: Registration succeeded for: 10003@Gizmo5 7474388373
    08:14:50.163 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 198.65.166.165:3478 over Transport 192.168.163.75:5060
    07:54:56.116 [CM506004]: STUN request to STUN server 198.65.166.165:3478 has timed out; used Transport: 192.168.163.75:5060
    07:54:50.085 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 198.65.166.165:3478 over Transport 192.168.163.75:5060
    07:34:56.022 [CM506004]: STUN request to STUN server 198.65.166.165:3478 has timed out; used Transport: 192.168.163.75:5060
    07:34:49.928 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 198.65.166.165:3478 over Transport 192.168.163.75:5060
    07:15:13.975 [CM506004]: STUN request to STUN server 198.65.166.165:3478 has timed out; used Transport: 192.168.163.75:5060
    07:15:07.960 [CM506004]: STUN request to STUN server 198.65.166.165:3478 has timed out; used Transport: 192.168.163.75:5060
    07:15:01.913 [CM506004]: STUN request to STUN server 198.65.166.165:3478 has timed out; used Transport: 192.168.163.75:5060
    07:14:55.882 [CM506004]: STUN request to STUN server 198.65.166.165:3478 has timed out; used Transport: 192.168.163.75:5060
    07:14:49.835 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 198.65.166.165:3478 over Transport 192.168.163.75:5060
    07:09:49.022 [CM504004]: Registration succeeded for: 10003@Gizmo5 7474388373
    07:09:34.475 [CM504004]: Registration succeeded for: 10002@Gizmo5 7472721772
    06:54:55.866 [CM506004]: STUN request to STUN server 198.65.166.165:3478 has timed out; used Transport: 192.168.163.75:5060
    06:54:49.819 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 198.65.166.165:3478 over Transport 192.168.163.75:5060
    06:34:49.772 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 198.65.166.165:3478 over Transport 192.168.163.75:5060
    06:14:55.835 [CM506004]: STUN request to STUN server 198.65.166.165:3478 has timed out; used Transport: 192.168.163.75:5060
    06:14:49.741 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 198.65.166.165:3478 over Transport 192.168.163.75:5060
    05:55:13.616 [CM506004]: STUN request to STUN server 198.65.166.165:3478 has timed out; used Transport: 192.168.163.75:5060
    05:55:07.600 [CM506004]: STUN request to STUN server 198.65.166.165:3478 has timed out; used Transport: 192.168.163.75:5060
    05:55:01.538 [CM506004]: STUN request to STUN server 198.65.166.165:3478 has timed out; used Transport: 192.168.163.75:5060
    05:54:55.491 [CM506004]: STUN request to STUN server 198.65.166.165:3478 has timed out; used Transport: 192.168.163.75:5060
  18. janofsky
    Jun 13, 2009
    14
    Amny luck getting Google Voice to work through Gizmo (sipphone) to 3x and having the audio work? Is this an issue with the rtp port or the codec selection?
