Help with Sonicwall TZ170
Discussion in '3CX Phone System - General' started by seanbts, Oct 12, 2010.
  1. seanbts
    Oct 12, 2010
    34
    I'm currently testing the 3CX software at the moment and need some help with configuring a Sonicwall Tz170. I've opened up all the necessary ports but when I run the Firewall checker, I get the following for all the ports:
    TCP TUNNEL Port is set to 5090. Response received WITH TRANSLATION 15293::5090. Phase 3 check passed with WARNINGS. Some functionality will be LIMITED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker.
    I gather this is to do with NATing, can you help with how to create Static Nats on the TZ170?
    Cheers, Sean
