Solved Help with Video (doorphone) and offsite 3CX
Discussion in '3CX Phone System - General' started by Kaz, Nov 2, 2017.
  1. Kaz
    Kaz
    Jun 11, 2017
    Hi Guys,
    as I am a 3CX "almost virgin" - :) I could do with some help on integrating Video from door phones into 3CX.
    My 3CX is hosted on my own virtual server In My Own Cloud (IMOC) :) - (v15.5/Deb) - It has a public static IP address and passes all firewall tests.
    The door phones and clients are all on the same private subnet (192.168.x.x)
    Calling to/from doorphones work fine. But Video does not. (Axis 8004/8005 door phones) - Call Recording is disabled for all extensions (as per a forum post somewhere)
    On the 3CX windows client - it does see the door-phone as a Video Call - but never presents video. Voice calls work fine. iOS client of course only see it as a voice call - but works fine too with voice.
    So what can I do to get video working? Has it something to do with 3CX registering the phones on the shared/NAT IP from my location (Dynamic IP via the 192.168.x.x nat)?
    /k
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,476
    67
    Your door phones should use one of the video codecs supported by the 3CX client: H263, H263+, VP8. Otherwise, it will not work.
  3. Kaz
    Kaz
    Jun 11, 2017
    ahh - 3CX only uses H263 - then it will never work :) as Axis only uses 264.
    thanks that cleared it up. Any chance of a 264 codec in the future?
