help!!!
Discussion in '3CX Phone System - General' started by mdeguzman, Oct 16, 2007.
  1. mdeguzman
    Oct 16, 2007
    hi,
    i'm using 3CX as SIP server in trying to make calls using one of the sample applications in Dialogic HMP, and I get this error in 3CX:
    [CM010001] Line configuration does not allow identification of the source of this call. Check Advanced Options for Gateways and Providers and match a field to a correct value from the following: Contact IP: '192.168.1.108'; From: 'iptB1T2_phfsdt007'; To: '101'; Rline: '101'; Contact: 'iptB1T2_phfsdt007'
    Do any of you have an idea on how to resolve this problem? :lol:
    Thanks in advance!
  2. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    That problem has a simple answer, Go to the Line/Voip line configuration go to the last tab, check "Use ip in contacts..." and below input 192.168.1.108
    Should work after that
