Solved Hide / close default group in soft client
Discussion in 'Windows' started by smartek, Jun 27, 2017.
  1. smartek
    Jan 12, 2016
    33
    13
    I have 3 groups created with 16 users. Unfortunately, in the 3cx soft client, it shows the 4 groups (with the default group). Is there a way to hide or close this groups to avoid showing... 32 users ?
    Thank you for your help.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,402
    535
    Hello @smartek
    You can either rename the default group and use that as one of your groups or you can remove all member from the default group. Removing all contacts from the default group will remove it from view in the 3CX client
    natero and smartek like this.
  3. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,528
    71
    Also, smartek, in addition to what Yannis said:
    if you're not interested in groups, then in the Windows client open the switchboard, click the settings button and there uncheck "Show group headers". In this way, you'll see only your extensions.
    Later edit: I forgot, in the same Settings page you can select also which group(s) you want to be shown, so you can deselect the Default one.
    #3 Vali_3CX, Jun 27, 2017
    natero likes this.
  4. smartek
    Jan 12, 2016
    33
    13
    Thank you both for your quick response, very appreciated !
    YiannisH_3CX suggestion works perfectly. For some reason, I didn't think one could remove a user from the default group :).
    natero likes this.
