Hide/disable ext in MyPhone and phone book**N/A
Discussion in '3CX Phone System - General' started by donhounsell, May 28, 2011.
  1. donhounsell
    Aug 3, 2010
    22
    I have several extensions which are set up as "Do not show this extension in 3CX MyPhone". However, these extension still show in the MyPhone Phonebook, and also in search results. I would like a way to hide these extensions altogether in MyPhone.
    Even when I disabled the extension, it still shows in MyPhone phone book and search results.
  2. nb
    nb Support Team
    Jun 7, 2007
    2,153
    172
    Re: Hide or disable extension in MyPhone search and phone bo
    This option does not hide the phone book entry. This option is designed not to show the whole extension in the extension status tab of the myphone.
    Phonebook will show all the entries you have.
