Hide id of outgoing call
Discussion in '3CX Phone System - General' started by ccuomo, Oct 29, 2016.
  1. ccuomo
    Oct 29, 2016
    5
    Greetings to all the forum,
    i installed 3CX on Windows 10. I have to hide the caller id of a single extension, but do not know where to make the action.
    Carry a simple schematic:
    Grandstream 1620 -> 3cx ---> cisco spa232 ---> isdn :oops:
    10,360
    226
    The default code (prefix) to block caller ID is *5. However, they would have to remember to use this each time. If your provider has a code used to block caller ID, you could create a separate outbound rule, only used by that one extension, and prefix the required digits. Then your provider would suppress the number.
  3. aberry
    aberry New Member
    Jan 13, 2015
    118
    7
    I also have a group that wants outgoing caller ID suppressed. I contacted the SIP provider for the dialing code to block, and created an outgoing rule for those extensions. Worked great.
  4. briankayser
    Jul 19, 2016
    49
    5
    Many phones allow you to add a prefix to all calls. This would require you to directly modify the phone's settings outside of 3CX but if you are only needing to do this on a few phones it shouldn't be a big deal.
    On a Grndstream 2160 (for example) under ACCOUNTx\Call Settings in the phone's web interface, you can put *5 in the "Dial Plan Prefix". With this it adds the *5 on every call. I just tested this. Even though it adds *5 to internal calls too, the remote extensions still show your name/ext (which I think you would want) but on on external call it shows as anonymous.
    You could also try putting "Anonymous" in for the extension's "Outbound Caller ID". Some SIP provides don't like that though.
    You will want to keep e911 in mind in whatever you do, even if you put a sticker on the phone that says it doesn't have 911 services.
  5. ccuomo
    Oct 29, 2016
    5
    According to the trace the phone is sending correctly the INVITE with "anonymous" and getting '403 Forbidden' with message 'Caller Is Forbidden' from the 3CX Server, can you please check this from the server side, and let me know.
    Please check if there is any option to accept Anonymous Calls on 3CX, since the server ignores those requests. If you assume other phones are able to dial with anonymous to the same server, please let me know, and provide with a trace accordingly, otherwise, please check why the server is forbidding the anonymous caller.
  6. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    You need to be more specific here. You got the right advise above.
    It seems as though you're now suddenly talking about incoming anonymous calls
    even though your original request was how to make outgoing calls with a blocked callerID.
    ... so what are you trying to do ? Accept anonymous calls (nothing to do), or MAKE anonymous calls.
    If you're trying to make it and getting that "403 forbidden" message, that's most likely not from the PBX but from your sip provider, OR you don't have the proper outbound rules set. What are you dialing that's giving you that message ?
  7. ccuomo
    Oct 29, 2016
    5
    the problem occurs with outgoing calls
  8. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,349
    274
    The invite coming from your phone to the PBX is invalid that is the reason the PBX sends back Forbidden.
    The extensions is allowed to send Anonymous in the first part but the sip:<> part should be the extension number and the part after the @ should be the domain the phone is a part off (the pbx host name or ip).
  9. ccuomo
    Oct 29, 2016
    5
    This is the response of the Grandstream support
    I just run several tests in our lab, i tested with our phones, and OTHER BRANDS as well, the From Header is always sent in the format you have attached, and the 3CX Server is always forbidding the caller with "403 Forbidden" and "Caller is Forbidden" message.
    I have tested on other PBXs and they accept correctly the anonymous calls with that format.
    Please check if there is any option to accept Anonymous Calls on 3CX or why exactly the calls are being forbidden from different brands. If you assume other phones are able to dial with anonymous to the same server, please let me know, and provide with a trace accordingly, it will be very helpful for us to see the right anonymous FROM header format that 3CX server accepts.
    Thank you.
    Best Regards,
    Driss
    #9 ccuomo, Mar 22, 2017
  10. ccuomo
    Oct 29, 2016
    5
    I can not understand how I can enter the dial plan the character #
    my dial plan is this:
    (* Xx | [3469] 11 | 0 | 00 | [2-9] xxxxxx | 1xxx [2-9] xxxxxxS0 | xxxxxxxxxxxx.)
    if you call the number *67#3451245123
    pbx comes on
    *67%23451245123
    How can I fix?
