Hide IVR, Queue and ring groups from phonebook
Discussion in 'Ideas' started by Gunnar Brynjólfsson, Jan 20, 2017.
Hide IVR, Queue and ring groups from phonebook 5 5 40votes
5/5, 40 votes
  1. Gunnar Brynjólfsson
    Jan 20, 2017
    5
    8
    I would like have the possibility to hide IVR, Queue and ring groups from company phonebook.
    We have customers that don't want the night IVR, and call flow ring groups visible in the company phonebook. They have many departments and different IVR for each one. This only clogs up the phonebook search.
    This option is already available for extensions, so why should it not be available for groups, IVR and queue.
  2. TimWinkle
    Oct 6, 2016
    6
  3. CDC1
    Oct 6, 2017
    5
    YES! There's no good reason why Digital Receptionist/IVR and Ring Group "extensions" should automatically appear in a phonebook visible to users, without admin options to NOT display those extensions. And there are plenty of reasons why a system admin wouldn't want users seeing or dialing those non-user extensions. It's simply bizarre that the option to "not display" in the company phonebook is available for user extensions, but not for specialized/non-user extensions. 3CX, please consider fixing this issue. Thank you!
    techdummy, natero and Satisfaction like this.
  4. techdummy
    techdummy New Member
    Sep 22, 2017
    211
    9
    Yes! Yes! Yes!
    I have no idea why any organisation would want all the employees to view all the queues available by default.
    The admin should have privileges to provide access to only those who needs to see these queues.
    Atleast, our organisation needs this badly.
    Please do something about this, as this is a must feature for us.
    Thank you.
  5. techclarity
    techclarity New Member
    Nov 14, 2014
    109
    50
    Yes, please make this available.
  6. mixig
    mixig Active Member
    Dec 13, 2011
    530
    12
  7. benk
    Nov 3, 2015
    6
    7
  8. mkb
    mkb
    Dec 14, 2015
    13
  9. Jeremy Bero
    Dec 29, 2017
    13
  10. kieferschild
    kieferschild New Member
    Jul 1, 2016
    170
    17
  11. Dominik Meier
    Jan 12, 2018
    8
  12. aws2p
    Jan 9, 2014
    55
    6
    +1
  13. purple
    Oct 25, 2016
  14. Hringvar
    Apr 9, 2018
  15. Brant Y
    Oct 24, 2017
    5
  16. billthenerd
    Jul 3, 2014
    19
  17. Wesley Hader
    Aug 27, 2017
  18. luckystrikes
    Apr 17, 2018
    14
    +1, I would add, even if you put the option "hide from company phonebook" you can still search for names or # in app and it displays. For example, if you start typing a matching letter it finds people anyway
  19. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,528
    71
    From 3CX client's point of view, if we hide them, they will no longer be visible in Forwarding Rules (where it's a well-defined entry called Forward to System Extension).
  20. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,575
    305
    I think where and when it shows needs to be rethought with maybe another option.
    If its hidden - it should still show up in Setup /Forwarding areas (maybe) - but not in Phonebook.
