Hiding group membership in Assistant
Discussion in '3CX Phone System - General' started by Lukas, Feb 11, 2011.
  1. Lukas
    Jan 23, 2011
    45
    Hi! Is there a way to hide group membership in Assistant?
    In other words: I don't mind an user to be able to see who are the other users in his same group, but, specifically, I would like to make it so that management extensions are not known company-wide (without hiding them). It would be perfect to have them listed under "not group members", in a very general way.
    Is it possible to achieve this?
    Thank you!
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    Hi, just so I understand correctly what you are trying to do
    Example
    Group A - Staff Members
    Group B – Managers
    From what you appear to ask, is it possible to hide the managers group from the Staff Group
    Is this correct?
  3. Lukas
    Jan 23, 2011
    45
    Correct. I'd like the staff to be aware of whether the managers' extensions are able to take calls, but I would rather not want everyone to know which extensions have management privileges...
  4. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    I am not sure if this will help you but you can give members of a group Admin rights.
    This means that they are effectively in the management group but only for the group they are in.
    So if you have 2 groups then it would work. If you have more than 2 groups and people need to manage both groups they have to be in management.
    Move the people who just need to manage the Staff group into that group and give them admin rights in 3cx.
    This way they will show up as just Staff members in the assistant but have extra options that others do not.
    As i said, it works if they just need to manage their group (Eg. team leader, supervisor, department manager) but not if they need to manage 2 or more groups, then they have to be in management. Also explain to people that Management group means management of all groups in 3cx and not some job promotion (that often helps clear most misconceptions)
  5. Lukas
    Jan 23, 2011
    45
    Mark, thanks for your input. Unfortunately I am in the situation where I am forced to put some extension under "Management", and you put your finger right on the sore spot: if it were called "sysadmins", "technical staff" or anything else I wouldn't have a problem. It's just the word "management" which makes it look like a humble technician has self-promoted himself where he does not belong. It's a matter of opportunity and of not irritating managers who can not be part of the management group... rather silly, I know -- but with so many words why choose "management" :p
    At the moment I solved the problem by creating an additional extension that is not listed in the Assistant only for management purposes, so there is no "management" group shown.
