High overall latency
Discussion in '3CX Phone System - General' started by snon, Oct 14, 2008.
  1. snon
    Jun 30, 2008
    we're running a 3cx v6 server on vmware ESX with phones connecting via VPN from a bunch of places. The network roundtrip times are in the 20-30ms range at any point and we've played around with the PBX delivers audio setting and other things but still get rather long (percieved) delays - especially on the conference server which we intend to use a lot, but right now only can use internally with people that accept the confusion of a roughly 2 second delay...
    CPU usage with 4-5 callers is in the 5% range, memory in the 50% range of 1Gb and no other indications of a problem is visible.
    My gut feeling is that we're looking at a buffering issue with the mediaserver somehow - can anyone share a light on what it does and if anything can be tuned?
    EDIT: The phones used are SPA942 with fw 6.1.3(a)
    Brgds
  2. tekknow
    Oct 3, 2008
    29
    We were previously using asterisk, and I can say that 3cx does generally suffer more latency.
    I have not used the conference feature, however after making all calls use re-invites it is clearly way better.
    I might also add that re-invites seem to work on 3cx where they have failed on Asterisk.
