HOL digital receptionist and prompt play
Discussion in '3CX Phone System - General' started by gehri, Jul 31, 2016.
  1. gehri
    Jan 28, 2015
    11
    when setting holidays in 3CX in v15 i'm facing with a problem.
    Normally when calling an extension with the "public holidays" flag on it, 3CX plays holidays prompt and then forward call to HOL digital receptionist. On HOL, 3CX won't play any prompt we set.
    Is it normal?
    Call -> Holiday prompt -> HOL DR with prompt (not playing) -> operator VM.
    Help!
  2. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    401
    @gehri,
    Are you sure that for DR HOL (Out of Office IVR) you have specified a prompt?
    Can you do the following from a 3CX Phone can you dial HOL, do you hear the prompt being played.
    Without logs cannot go further, so I suggest you to do the following.
    1. Enable Verbose Logging for 1 call then put it back to Low.
    2. Make a call and see from IVR Log if prompt is being taken from the correct path, etc.
  3. Sopock
    Sopock Member
    Jul 11, 2012
    448
    20
    LF: Fix line breaks
    that might be difficult since there is a problem with IVR log in default editor :!:
  4. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    401
    Try notepad++ or any tool editor except notepad :)
