Solved HOL IVR not showing up in extensions
Discussion in '3CX Phone System - General' started by dustycr, Jan 11, 2018.
  1. dustycr
    Mar 7, 2017
    21
    after we restored a backup, the hol ivr extension is not showing up in the sip trunk options for the outside office hours.
    I checked the system extensions in the dashboard and the hol ivr is online and running but when i try to use it under sip trunks -> route calls to -> Destination for calls outside office hours -> Extensions, its not showing up.
    Does anybody have an idea what could be the cause of the problem?
    Thanks in advance.
    (Reboot didnt help)
  2. nitrox
    Sep 10, 2016
    95
    11
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,340
    533
    Hello @dustycr
    HOL IVR is no longer available as a destination for out of office hours as it is reserved specifically for holidays. You will need to create a new IVR and forward calls to that one for non holiday office hours.
    nitrox likes this.
  4. dustycr
    Mar 7, 2017
    21
    good to know :)
    Thread can be closed.
