HOL IVR not working
Discussion in '3CX Phone System - General' started by TCF, Feb 5, 2018.
  1. TCF
    TCF
    May 6, 2015
    92
    My HOL IVR is not working. If I set dates to be a Holiday instead of going to the HOL it goes to my Extension for Office Closed, as if it is just outside normal business hours. In my Trunks the box is checked for Play holiday prompt when it's a global holiday. This doesn't seem to make a difference. Am I missing something? I'm not against creating a new IVR if I need to, but how then would I tell 3cx to use the new IVR when I set Holidays in Timezone & Office Hours Settings?
  2. jimbo59
    jimbo59 Member
    Nov 17, 2017
    358
    77
    You need to create a new IVR. You can't research as HOL and IVR are 3 letter words and somebody hasn't set the forum up to search for such terms.
    TCF likes this.
  3. TCF
    TCF
    May 6, 2015
    92
    Ok thank you for letting me know this. How do I close this thread?
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,443
    282
    Hello @TCF
    When you set a holiday and select the option "Play holiday prompt when it's a global holiday" the PBX should route the call to the HOL IVR automatically. If the option is not selected then the destination will be out of office hours.
    With that in mind check that the option is selected under trunk settings and under any inbound rules you might have. Each inbound rule has its own option that needs to be selected.
