Hold music from VoIP Providor
Discussion in '3CX Phone System - General' started by RobLloyd, Aug 16, 2007.
  1. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    Does anyone else get a different hold music than what 3CX provides? With both the Linksys SPA9000 and 3CX systems, outside callers sometimes get a different hold music that what they should.
    I asked my ITSP and they said that's strange. Not sure how else different music would get in there.
    It doesn't happen all the time and I could probably reproduce it.
    Seems like my ITSP is getting a hold request and they inject their own music.
  2. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    I can reproduce it easily now - I call in, DR picks up and I enter an extension. If I press XFER I get different hold music than the one from 3CX.
  3. Costas3CX
    Costas3CX New Member
    Jan 23, 2007
    217
    Why don't you try to go to that extension that you tried sending the call to, with DR, and go the the advanced extension options in 3cx Management console, and UNtick support replaces, and TICK bind to media server. Let me know if this changes things at all..
    Regards...
    Btw , what is the brand/model of the extension you are forwarding to?
  4. rapidtechltd
    Aug 13, 2007
    Un tick supports re invites
    I had the same problem with VOIPFONE . i unticked supports reinvite and it now plays the on hold music i selected in 3cx
  5. silentfun
    silentfun Member
    Dec 11, 2006
    364
    sometimes there is a holdmusic generated by the phone that transfer the call - but it depends on settings of phone and pbx
  6. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    In current version - PBX manages hold requests in the same manner independently where from it is coming.
