- Joined
- Oct 11, 2007
- Messages
- 30
- Reaction score
- 0
I'm experiencing some very strange stuff. So I've setup a little local phone system involving two Polycom 650's, a laptop as the server and X-Lite to show the problem.
HYPOTHESIS: There is something wrong with the Media Server
Windows firewall is turned off. Everybody is plugged into a D-Link DGL-4300 I’m not sure about the UDP and TCP packet blocking settings.
Problem Scenario 1:
Extension 101 calls extension 102 -- both extensions are marked as "external" and "bind to media server" is OFF.
102 Rings
102 puts call on hold
102 take call off hold
102 puts call on hold -- but it won't work. It doesn't put the call on hold
I keep pushing hold and it doesn't do anything.
Also, while on hold, I do not hear the music. Also, extension 101 does not properly report that it is on hold
102 ends call, but 101 still think's the call is connected.
After 20 seconds, 101 finally ends the call itself.
09:27:45.625 StratLink:nHangUp [CM104001] Call(34): Ext.102 hung up call; cause: unknown
09:27:13.375 CallLegImpl:nConnected [CM103001] Call(34): Created audio channel for Ext.101 (192.168.1.142:2262) with third party (192.168.1.154:2248)
09:27:13.375 StratInOut:nConnected [CM104005] Call(34): Setup completed for call from Ext.102 to Ext.101
09:27:13.375 CallLegImpl:nConnected [CM103001] Call(34): Created audio channel for Ext.102 (192.168.1.154:2248) with third party (192.168.1.142:2262)
09:27:10.703 CallConf:nProvisional [CM103003] Call(34): Ext.101 is ringing
09:27:10.328 CallConf:nIncoming [CM103002] Call(34): Incoming call from 102 (Ext.102) to sip:[email protected]
Problem Scenario 2:
I mark both extensions external OFF. Bind to Media Server is OFF
Extension 101 calls 102
102 Rings
102 puts call on hold -- WORKS
Also, while on hold, I do NOT hear the music.
Extension 101 DOES properly report that it is on hold
102 ends call
101 ends call normally
09:37:35.625 StratLink:nHangUp [CM104001] Call(39): Ext.101 hung up call; cause: BYE; from IP:192.168.1.142
09:37:29.250 CallLegImpl:nConnected [CM103001] Call(39): Created audio channel for Ext.102 (192.168.1.154:2258) with third party (192.168.1.142:2224)
09:37:29.234 StratInOut:nConnected [CM104005] Call(39): Setup completed for call from Ext.101 to Ext.102
09:37:29.234 CallLegImpl:nConnected [CM103001] Call(39): Created audio channel for Ext.101 (192.168.1.142:2224) with third party (192.168.1.154:2258)
09:37:27.718 CallConf:nProvisional [CM103003] Call(39): Ext.102 is ringing
09:37:27.468 CallConf:nIncoming [CM103002] Call(39): Incoming call from 101 (Ext.101) to sip:[email protected]
Problem Scenario 3:
Extension 201 (X-Lite) calls 102
102 Rings
Also, while on hold, I DO hear the music.
Extension 201 DOES properly report that it is on hold
102 ends call
201 ends call normally
When I reverse things – I hear no music from extension 102.
Clearly there is something wrong with the Media Server. What am I doing wrong?
Problem Scenario 1:
102 Rings
Problem Scenario 2:
102 Rings
102 ends call
Problem Scenario 3:
102 Rings
102 ends call
