Hold Reminder ring
Discussion in '3CX Phone System - General' started by jeff yager, Jun 17, 2013.
  1. jeff yager
    Oct 10, 2012
    17
    Hello All, looking to implement a ring/reminder tone when a call is on hold for X amount of time. How can I go about doing this?
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    65
    If speaking to "on hold" only, then these are parameters usually set in the phone. Yealink as an example, has a setting that enables or disables the tone and then another that sets the interval by which the tone will sound...if enabled.
  3. jeff yager
    Oct 10, 2012
    17
    Using all grandstreams and MOSTLY gxp2120's
  4. lneblett
    Sep 7, 2010
    2,086
    65
    I took a quick look at the documentation for the 2120 and did not see a similar setting. You might wish to visit the GS forum and submit a query on the matter and perhaps they can advise further on how to do, if available, or perhaps include in a future firmware release. In the meantime, you could explore "parking" and its available options. Take a look at the settings and you will see some options on how it works.
    The 1450 model has a call waiting tone enable and disable which I did not see in the 2120. Sometimes, the manufacturers will use essentially the same methodology for the two (call waiting/hold functions with regards to tones) but I could not really tell if that was the case.
