hold / resume not work
Discussion in 'Android' started by bluetel2, Aug 23, 2010.
  1. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    6
    hi all,
    it's on galaxy s and android 2.1
    tks
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,455
    92
    When you say Hold and Resume does not work what exactly do you mean? Does the 3CXPhone crash? Or does nothing happen?
  3. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    6
    Hi Leonidas,
    in fact, when i take call, and make hold, the caller is on hold it's ok, but when i want to resum... no resum, caller is yet on hold.
    11:34:50.506 [CM503008]: Call(1404): Call is terminated
    11:34:50.131 [MS211000] C:1404.2: 192.168.1.236:16400 is delivering DTMF using RTP payload (RFC2833). In-Band DTMF tone detection is disabled for this call segment.
    1Ext:Ext.123@[Dev:sip:123@192.168.1.90:1100;rinstance=3b99b2ccb31add88]
    11:34:42.522 [CM503007]: Call(1404): Device joined: sip:131@192.168.1.236:5060
    11:34:42.522 [CM503007]: Call(1404): Device joined: sip:500@192.168.1.94:5060
    11:34:41.022 [CM505001]: Ext.131: Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA922-6.1.3(a)] PBX contact: [sip:131@192.168.1.42:5060]
    11:34:41.022 [CM503002]: Call(1404): Alerting sip:131@192.168.1.236:5060
    11:34:40.959 [CM503025]: Call(1404): Calling Ext:Ext.131@[Dev:sip:131@192.168.1.236:5060]
    11:34:40.912 [CM503004]: Call(1404): Route 1: Ext:Ext.131@[Dev:sip:131@192.168.1.236:5060]
    11:34:40.912 [CM503010]: Making route(s) to <sip:131@192.168.1.42>
    11:34:40.912 [CM505001]: Ext.500: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone for Android 1.1.13] PBX contact: [sip:500@192.168.1.42:5060]
    11:34:40.897 [CM503001]: Call(1404): Incoming call from Ext.500 to <sip:131@192.168.1.42>
    tks advance
  4. LeonidasG
    Nov 19, 2008
    1,455
    92
    I'd try disabling your firewall momentarily and try the test again and see what happens.
  5. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    6
    i have disable firewall on server but the same result. it's like server don't see resume fonction.
    i send you per mp the 3cx log
  6. StefanW
    Jun 2, 2009
    1,210
    85
    may better send a wireshark pcap to see if and how the resume come to the system.
  7. LeonidasG
    Nov 19, 2008
    1,455
    92
    It would be best to send a Wireshark Capture to lg@3cx.com
    The Logs of the phonesystem won't say much in this case.
    Also, what is the nature of the call? Is it an Internal Call?
  8. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    6
    can you send me per MP your email add, i will send you the wireshark file.
    tks
