Holiday Settings
Discussion in '3CX Phone System - General' started by gmr, Dec 30, 2011.
  1. gmr
    gmr
    May 18, 2011
    10
    I have been unable to set holidays on 3CX 10 sp5. When I access configure holidays, default settings for Aug 1 - Aug 5 appear. I have repeatedly removed these and then entered new settings for the current holiday season. The new settings do not alter my office hours or after hours IVR. When I check the Configure Holiday settings, the old Aug settings reappear and the new ones I entered have vanished. I have tried this repeatedly with and without restarting all services. My customers are expression frustration with this problem. The Office Hours and After Hours settings are adequte but the holiday configuration is poor. Thoughts?
    11,095
    327
    Are you using the Windows Management Console icon, or your browser? Try using the icon.
  3. gmr
    gmr
    May 18, 2011
    10
    I am using the Windows Management Icon on the 3CX server Windows 2003 Server
  4. efounco
    efounco New Member
    Sep 28, 2011
    148
    Add or remove them from the holiday sub-menu first. Then, click "Apply" on the settings menu.
    If you don't click "Apply" before leaving the settings menu, your changes will be discarded.
  5. gmr
    gmr
    May 18, 2011
    10
    I had not been hitting apply. This appears to have worked. I will report on it later. THANK YOU.
  6. efounco
    efounco New Member
    Sep 28, 2011
    148
    That's OK, I did the same exact thing the first time I used it. Having a sub-menu to add and remove dates and then needing to "Apply" the changes on a separate menu is a silly design IMHO...
  7. gmr
    gmr
    May 18, 2011
    10
    I agree. Thanks again.
