Host PC sizing - Call recording - lots of users
Discussion in '3CX Phone System - General' started by ccomley, Feb 11, 2016.
  1. ccomley
    Apr 6, 2011
    95
    I wonder if anyone can give me a feel for a situation we've not been in yet. I want to be sure we don't under-spec the host platform for a 3cx system which will have
    - 300 or so desks
    - 100 or so concurrent calls
    - RECORDING of all calls ACTIVE
    It's the third item which has me worried - turning this on means all calls will be proxied via the 3CX server not going direct from phone to phone/gateway, and writing 100 separate calls to disk at the same time... anyone done this sort of thing for a user? Did you need a souped up machine to cope?
  2. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,083
    10
    Try it, it should work, as recording happens with direct access to local hard disks, i.e. the disk controller should handle I/O operation/
