Hosted PBX + Yealink CTI + Cloud workplace
Discussion in 'Ideas' started by rsh, Nov 11, 2015.
  1. rsh
    rsh
    Mar 25, 2011
    18
    Since version 14 it isn't possible anymore to use (Yealink) CTI with a remote 3CX client (so the 3CX Soft client isn't in the same local network as the phones)
    A lot of customers are using cloud workplaces, so this is a very common issue..
    There are also situations that the voice network is separated of the data network. Then the CTI does also not work.
    Please fix this, so the CTI can be used again in every (network) situation.
  2. rsh
    rsh
    Mar 25, 2011
    18
  3. rsh
    rsh
    Mar 25, 2011
    18
    Still no solution for this problem? :|
  4. DSXDATA
    DSXDATA New Member
    Oct 20, 2015
    185
    64
    Until a better answer comes along: use an SBC and then CTI will work perfectly.
