Hosted Setup...incoming yes, outgoing NO!
Discussion in '3CX Phone System - General' started by Lenardb79, Mar 20, 2018.
  1. Lenardb79
    Mar 16, 2018
    I have the google hosted setup with callcentric as our provider. Incoming calls no issue, but we have for testing a windows 10 softphone and an android softphone. I have a GXV3140 (used on a 5 yr old on-premise version of 3cx and it worked then) but will not provision now...but ill deal with that next.
    I set the outgoing rules as I am used to and as per the 3cx manual and callcentric/3CX (they support 3cx) and still no go.
    Ideas?
    anyone with callcentric and 3cx can give me their outgoing setup or any other advice.
    BTW...the softphones just upon hitting dial, say "Declined" all I want is strip the +1 and then dial 9 and the 10 digit # im calling. while still allowing for me to dial the 3 digit extensions wit now issue
  2. mariosM_3CX
    mariosM_3CX Support Team
    Nov 1, 2017
    406
    40
    Hello @Lenardb79
    It might be that the call is not matching any outbound rule. Check your activity log for more info as to why the call is declined.
    Also, make sure that in the extension settings >> Options you did not enable the option to disable external calls.
    Can you share a screenshot of your outbound rules and format of the number you are dialing?
    JCLloyd likes this.
  3. Sampl
    Jan 4, 2018
    27
    5
    are the Caller ID fields filled in on the extensions?
  4. Lenardb79
    Mar 16, 2018
    when I copy/paste logs and try to post it says I am trying to post spam....:(
    I do not have an extension > then, Options area...now under extensions, I do not see anything that says under any tab "disable external calls" or similar
    ...and yes Outbound Caller Id is filled in, should I leave empty?
  5. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,255
    203
    Try removing the + sign from the prefix, as I am guessing your outgoing calls do not have + sign - activity log will confirm this
    Instead of the + sign on the prefix, add one extension number into the extension field to see if this works.
    I would say you need to setup your outbound rules correctly, https://www.3cx.com/docs/manual/outbound-rules/
    If the number being dialled does not match any of the outbound rules, the call will fail - any failures look in the activity log to see the format of the number being dialled.
    #5 Saqqara, Mar 21, 2018
  6. Sampl
    Jan 4, 2018
    27
    5
    Nope that is good :). I remember having this very issue, was able to receive but not call out. the issue was that there was no number in the caller ID field that was registered on the trunk so it couldn't resolve.
  7. leejor
    11,129
    330
    I'm with Saqqara. Simplify your outbound rules using only numeric characters, to see if that works. hen later , incorporate additional rules that make use of + and convert to the international/national prefix. Post an Activity Log of a failed call so we can see how far it gets.
