Hot Desk: Advanced Mode; Yealink Phone T26
Discussion in '3CX Phone System - General' started by Arif, Mar 4, 2012.
  1. Arif
    Mar 4, 2012
    I am trying to implement the Hotdesk feature on 26T Yealink Phone. The basic mode works fine. But it requires to enter the server IP address every time, which as an admin, I am not very fond of.
    In the Advanced mode, the user has to input just the username and password. However it requires to enter an HTTP URL to a script file in the 'value' field after selecting 'Hot Desking' in DSS keys. I have searched alot but I am unable to find even a sample file.
    http://www.yealink.co.uk/assets/Document-Download/How%20to%20use%20Hot%20Desking%20on%20Yealink%20phones1.1.PDF
    As you can see in the above link, there is a 'init.php' in the 'value' field. I would like to know where i can get this 'init.php'
    Any help would be much appreciated.
    Thank you
  2. Ian Joyce
    Oct 9, 2009
    51
    Arif,
    Are these the instructions you followed?
    http://www.3cx.com/blog/docs/hot-desking-with-3cx-phone-system/
  3. Arif
    Mar 4, 2012
    Ian,
    Yes. I followed those instructions. Selected Hot desking and left the value field blank.
    But the menu on the phone is not as depicted in the pictures on that page. The menu i get is
    -clear all config
    -1 register name
    -2 phone number
    -3 password
    -4 server
    -5 outbound proxy (not needed)
    I have to enter fields from 1 to 4. If server IP is not entered, I get an error message 'Invalid Server'
