Hot keys and 3cx phone for android
Discussion in '3CX Phone System - General' started by jochanan, Aug 14, 2013.
  1. jochanan
    May 12, 2011
    12
    The new interface of the myphone/phone looks great. But there are two things.
    1. Why is the Hot key function changed to this devious way? Normaly I selected a number, pressed F9 or some other F-key. Now I need to select the number, pres ctrl-c, then press ctrl or alt or shift with another key. The functionality of the hot key is gone, cause I am faster to touch the number on my desk phone.
    2. Is there a simple way for the following: I have a desk phone and the phone for android. The push functionality is awesome,but when I am at the office, my desk phone and android phone is ringing. I can not disable the phone on android for a while. When I use the "Do not disturb" or the status to away or something, my desk phone is also disabled.
  2. rogueblackburn
    Aug 11, 2013
    42
    Yes, I also got grumpy when I saw that...
    On your other point. Do you mean that you can't stop the app (Menu/Exit)?
