Hotdesk BLF
Discussion in 'Ideas' started by jakem, Apr 3, 2018.
Hotdesk BLF 5 5 1votes
5/5, 1 vote
  1. jakem
    Apr 3, 2018
    Hey!
    I use the Grandstream GXP2160 for a lot of my users, and being able to assign the BLF fields either directly to the hotdesk phone or by using the exact same configuration as is listed on the Extension would be hugely helpful. The current implementation where it dumps physical BLF lights into the Virtual BLF screen is frustrating, to say the least.
    craigreilly likes this.
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,551
    298
    are you starting at the correct place?
    position 23 is the starting point for physical BLF's on the 2160.
  3. jakem
    Apr 3, 2018
    Yep! Works just fine if you set up on the extension, but if that extension logs in via HotDesk it smashes them all into a list in BLF1 through BLF20, even though they are configured in 22-42.
