Hotdesking Auto-Logout
Discussion in '3CX Phone System - General' started by Alex92, Mar 1, 2018.
  1. Alex92
    Feb 14, 2018
    5
    Hello All,
    Apologies if this is a simple question however I have not been able to find an answer thus far.
    We are using 30 Yealink T-29G phones for hotdesking at one of our offices. Staff are able to login but will often forget to logout.
    Are we able to set a global configuration to force logout of hotdesking phones at a certain time? Or alternatively set a maximum amount of time for which one can be logged in before being logged off?
    Kind Regards,
    Alex
  2. eddv123
    eddv123 Well-Known Member
    Aug 15, 2017
    1,404
    186
    Hi Alex,
    No not as of yet, this is a commonly requested feature.
    As the administrator you can globally log people out in the 3CX management interface if they leave themselves logged in however.
  3. Alex92
    Feb 14, 2018
    5
    Thanks for the response!
    I guess we will continue to manage it manually until a solution is introduced.
    Regards,
    Alex
  4. eddv123
    Aug 15, 2017
    1,404
    186
    Yes, I did have a check to see if anything had been added in the latest service pack release but it doesn't seem so.
    I would check the ideas site and see if there is a feature request there-and either vote for it or raise you own (on the event one doesn't exist).
  5. mariosM_3CX
    mariosM_3CX Support Team
    Nov 1, 2017
    406
    40
