hotel industrial
Discussion in '3CX Phone System - General' started by dangmoss, Jan 29, 2015.
  1. dangmoss
    Oct 9, 2014
    26
    How does one go about using or getting analog 2 line phones to work with 3cx?
    I know I can get fxs adapter etc... and get them on the system but my question is
    How do you get like 100 ports for a hotel for example
    10,375
    231
    ATAs are available that support large numbers of lines. With 100 lines you'd probably have to spread them across several units. Best to stick with ATA's that are supported by 3CX as you probably want something that can be auto-provisioned.
    http://www.3cx.com/support/
  3. dangmoss
    Oct 9, 2014
    26
    Which ones support a large #?
    I dont see any
  4. leejor
    10,375
    231
    The Patton Smartnode SN4932 will support up to 32 FXS ports.
    http://www.patton.com/voip-router/sn4900/
    Finding the proper template is the trick. You might want to contact Patton directly.
    http://www.patton.com/resources/index.asp?a=12&
    I'm sure that there are other larger ATA units as well. It is a matter of finding a supported device, or a manufacturer that works closely with 3CX and can supply a template for provisioning.
    there are probably are other forum members that have been involved in a large hotel installations and could provide some insight. Analogue sets are still quite common in that environment given the durability, and if they wish to re-use existing sets, or re-wiring for SIP sets is out of the question.
