Hotel module and voicemail
Discussion in 'Ideas' started by cgm, Sep 25, 2017.
  1. cgm
    cgm
    Aug 31, 2009
    10
    The ability to clear and set extensions for an user webclient is great. The name, mobile number, and email address can all be set directly. However, There is no way to set the voicemail pin. So a receptionist can check in a new party but she can't tell them what their voicemal pin is going to be or set it for them. In order for this feature to be useful, we need to give that ability to the person responsible for check in and out a client. Otherwise, I either have to give them admin privileges or involve an administrator every time a guest check in.
    Thanks,
    Chris
  2. Silly English Kniggit
    Sep 13, 2017
    215
    77
    Why would you enable voicemail PIN for a hotel guest phone?
    I've never seen this, either as system installer - or as hotel guest. Enabling PIN is bound to cause problems - as a guest even if you told me, I'd probably forget in five mins anyway, or demand you change it to 1234 etc.
