Hotel Module Enable "PIN Protect" on Check-On
Discussion in '3CX Phone System - General' started by SilverReefCasino, Jul 22, 2014.
  1. SilverReefCasino
    Oct 18, 2013
    6
    Using Version 12 with Hotel Module
    When Checking a guest into a room, the Room Extension, in Extension-> Options -> Restrictions "Disable External Calls" will go from "checked" to "unchecked" ... Normal. But,it will also check the "PIN Protect" box, forcing Hotel Guest to use the "PIN Protect" Feature. We don't want this... How can we disable this feature from being checked.
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    Hi there,
    Just tested it on latest hotel build and the PIN checkbox was not changed neither on checkin or checkout.
    Please check you are running latest service pack 6 and latest hotel build. Always perform backup for each of those before going upgrades.
