- Joined
- Nov 20, 2009
- Messages
- 24
- Reaction score
- 0
Anyone out there using the hotel module ?
We have a V8 install planned to be upgraded in a couple months but in the meantime, the wake-up calls calendar gives us this error on submit, any idea ?
We are using Windows vista and it is up to date, running 3CX phone system V8 with hotel module.
Product is not supported anymore by 3CX and client does not want to upgrade before end of 2012 since everything works just fine apart from this new error on the hotel module.
Server Error in '/Hotel' Application.
Object synchronization method was called from an unsynchronized block of code.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.ApplicationException: Object synchronization method was called from an unsynchronized block of code.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[ApplicationException: Object synchronization method was called from an unsynchronized block of code.]
Gizmox.WebGUI.Server.Content.ProcessRequest(HttpContext objHttpContext) +1246
[HttpException (0x80004005): Object synchronization method was called from an unsynchronized block of code.]
Gizmox.WebGUI.Server.Content.ProcessRequest(HttpContext objHttpContext) +4162
System.Web.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +181
System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +75
Source Error:
Stack Trace:
