- Joined
- Dec 8, 2011
- Messages
- 13
- Reaction score
- 0
Just installed the hotel module v2.0.22658 and everything seems to be functioning correctly except the wake up calls. I check in a guest, select the guest and set wake-up call, the wake-up call shows in the console but when the time comes to initiate the call, I see a pop-up box saying:
3CX Interface -- Webpage Dialog
The wake-up call to extension: 1501 has failed.
Is there a log somewhere I can look at to try and track down the problem? I have no problem calling that extension from other handsets or making calls from that extension. I have setup the digital receptionist and used a default .wav file that I can hear if I dial the receptionist manually. Any suggestions are appreciated.
