Hotel PMS integration with FOSSE
Discussion in '3CX Phone System - General' started by JasonR, Nov 20, 2017.
Tags:
  1. JasonR
    Nov 20, 2017
    Has anyone installed 3CX hosted or otherwise an integration with the FOSSE PMS system? They are ising a serial connection to communicate between the PBX and the PMS. I see that 3cx used TCP but has anyone used SERIAL?
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,083
    61
    Absolutely not an issue. I use a Comtrol RTS-1 which is an Ethernet to serial adapter. This is a single port version, but they also make others in various port sizes. Simple to setup and has a port viewer function that allows you to see the communications between 3CX and the PMS in real-time. Been using them for over 5 years and never had one fail.
    I do not have experience with the FOSSE system and a Google search did not reveal any details of how the PMS to PBX function works. I can only caution you to make certain that the protocol matches that which 3CX supports.
