Hotlines dial codes ignored
Discussion in '3CX Phone System - General' started by mavik, Mar 20, 2018.
  1. mavik
    Apr 22, 2016
    I have an installation where I can dial a hotline. It connects but if I try to enter any number to pass a queue the digits entered are ignored. I don't see an option or anything in the log. Is someone able to point me into the right direction please.
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,083
    61
    Sorry, need a little more info as you are not telling us if you have a 3CX site that tries to dial out to a queue at another location or if someone is dialing in and getting to a queue and cannot get it to respond.
    I assume the first, in which case, change the DTMF format to inband on the device that is used to dial out and then try.
  3. mavik
    Apr 22, 2016
    Yes, you are right. I'm dialing out and the queue at the other side doesn't react to my pressed numbers.
    Do you know where I change the DTMF format
  4. leejor
    10,752
    285
    What type of trunking, and what make of set(s), are you using?
