How AC-211 phone adapter from SunRocket can be used with 3CX
Discussion in '3CX Phone System - General' started by pogosian, Oct 15, 2007.
  1. pogosian
    Oct 14, 2007
    Please anyone can help me with setting up AC-211 phone adapter from SunRocket. I have no problem to use CounterPath soft phone, but when I am trying to setup phone adapter it is not registering.
  2. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
  3. pogosian
    Oct 14, 2007
    Mirzab, thank you for your reply. I already unlocked AC-211 phone adapter and had no problem setting it up with sipphone.com service. I just having problem to set it up with 3CX service. Any help will be greatly appreciated.
    It is not registering to the server.
  4. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,994
    304
    Mirzab is right - you'd best look at getting another VOIP adapter. The one you mentioned is not supported.
  5. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    I had a couple Sunrocket gizmos - Linksys 2102 I think they were. But after trying for several hours to get the password to unlock the device I just tossed them. Wasn't worth my time.
