how bridge?
Discussion in '3CX Phone System - General' started by MasterX, Jan 8, 2011.
  1. MasterX
    Oct 2, 2008
    28
    hi,
    how can I create bridges on my phone system?
    dipende dalle chiamate simultanee, sempre?
    10,594
    255
    Did you look through the manual? What version are you using? Is it a 3CX PBX at the other end?
  3. MasterX
    Oct 2, 2008
    28
    bridge between 3cx pbx only
  4. leejor
    10,594
    255
    Well, you did answer one of three.
  5. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    And in 2 languages.... ;-)
  6. MasterX
    Oct 2, 2008
    28
    where are the answers??
  7. sigma1
    Nov 20, 2009
    542
    Since you already got this reply in english, please let me share it in Italian as well:
    Nel manuale puoi trovare the direzioni per creare un bridge tra due 3CX PBX
    Il collega Leejor ti ha cheisto 3 cose, non hai resposto all2 2 domande importanti...
    The collegue, Leejor asked you 3 questions, you did not answer the 2 most important ones...
  8. MasterX
    Oct 2, 2008
    28
    I want to know the maximum number, not how to do
    I obviously have read the manual, is a useless question
    for release, what's the difference? i have the version 9
  9. leejor
    10,594
    255
    This was your original question, not how many you could set up, at least, not in english. I asked which version because unless you use the demo code on the free version then you can't set up any. Otherwise the only limit is the number of concurrent calls, based on your licence.
